Cutting Body Lift Spacers
Old Dec 12, 2008 | 05:13 PM
rhale's Avatar
hey guys/gals,
i have searched to no avail! i currently have a 3" body lift that i want to cut down to 1". Has anyone done this? i am wondering if it will affect the strength of the spacers. i'll include pics. thanks in advance!!
Old Dec 12, 2008 | 05:19 PM
GVOLCRunner's Avatar
Im sorry, did you say go down?
Sure. Cut em up.
Old Dec 12, 2008 | 05:21 PM
rhale's Avatar
I know sounds CRAZY! but i'm wanting to lower my COG. currently running 4" suspension with the 3" body lift on 35's
Old Dec 12, 2008 | 05:28 PM
well hell..just get rid of the spacers all together.
but yea, cutting them wont make them weaker. That rubber is dense and strong.
Old Dec 12, 2008 | 05:31 PM
swapped89's Avatar
watch the spacer on the steering rod you might need to remove it if your kit had one to begin with. And your bolts will be way too long. so you'll probably need to get new bolts. iwas thinkin about doin the same thing. and cutting the spacers is fine just make them straight and level.
Old Dec 12, 2008 | 05:37 PM
rhale's Avatar
i have to check the steering rod. i figured the front bumper brackets, steering, all spacers, radiator bracing, and the fill tube for the gas tank. anything i forgot?
Old Dec 12, 2008 | 05:57 PM
4Crawler's Avatar
Won't hurt the blocks, just make sure to get the cut square so the blocks sit flush as those kind of blocks can fracture with uneven weight on them. Also, figure on getting new body mount bolts, most bolts only have an inch or so of thread on them, so at 2" shorter, the nuts will bottom on on the unthreaded part of the bolt.
Just an FYI that dropping 2" in body lift will only lower your CG about 1/2":
- http://www.4crawler.com/4x4/ForSale/...it.shtml#Lifts
Old Dec 12, 2008 | 06:28 PM
sa51's Avatar
glad to see someone going lower on their body lift. go for it! just make sure u cut em level and get new bolts
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
terminator
Jul 27, 2015 07:13 PM
ksmudrunner99
Jul 21, 2015 05:33 AM
