cracked t-case?
Old Aug 22, 2009 | 07:41 AM
fishnick's Avatar
cracked t-case?
I was cleaning up my 23 spline t-case yesterday when I noticed what looked like cracks, they don't seem to be deep and they feel like ridges not cracks when you run your finger across them. Do I need to worry about this?
Old Aug 22, 2009 | 07:59 AM
Kiroshu's Avatar
Looks like age craking to me. Alot of old aluminum that has high pressure on it all the time has these kind of cracks. They don't look serious but i nthe long run could be. I'd just keep driving it unless you wanna change it? Go to a junk yard and get one.
Old Aug 22, 2009 | 08:10 AM
fishnick's Avatar
I have another forward shift t-case and as I understand it the only difference is the input gear, if that is right I could just swap the 23 spline input into the 21 spline case and use that case?Would that work?
Old Aug 22, 2009 | 09:02 AM
CyMoN's Avatar
those lines come from casting and they are not cracks you see it a lot on aluminum to find out if they are actually cracks you could use the dye and black light.
Old Aug 22, 2009 | 02:40 PM
fishnick's Avatar
That makes a lot more sense because I took a closer look and can see that they are small ridges, not cracks.
Is it better to use a gasket to join the transfer case to transmission or do you guys just use permatex?
kawazx636
Oct 6, 2021 03:03 PM
alexcarey
Oct 14, 2015 06:05 PM
puddlepirate
Sep 29, 2015 08:02 PM
toyotasaurus
Sep 24, 2015 03:30 PM
