coolant in water..again...
Old Mar 6, 2006 | 06:55 PM
toywheelin05's Avatar
ok so heres the deal. i thought i had blown my headgasket on my 22re. When i pulled the head it was warped and the cam was garbage and springs and valves were too. so i went with an engnbldr street rv head with a new lc engineering header. i figured i better do a new timing chain, timing cover, so all new top end. put everything back together and thought my problem was fixed. started her up yesterday and wouldnt you know... white oil. my question is... is there any other common places for a leak? or am i looking at an internal crack in my block? so any help would be appreciated. if i have to end up getting a new block i think i might go the turbo route and get some turbo pistons and build myself a turbo while its out. what do you guys think?
Old Mar 6, 2006 | 07:05 PM
Yoda's Avatar
I would run it a short time and dump the oil and change filter. Refill and run again. Residual water can make it look like it is still leaking.
Old Mar 6, 2006 | 07:25 PM
thanks for the advice, i tried that i have run 8 qts, 2 filters and many gallons of water... thanks anyway
Old Mar 7, 2006 | 07:24 AM
Sporin's Avatar
Similar issues with my truck before I got it. BOTH PO's replaced the HG with no fix. Turned out to be a leak in the TC cover gasket and a weep in the freeze plug ("molly plug??) under the cam (in the head).. Not the HG as suspected.
Old Mar 12, 2006 | 10:21 AM
i changed the timing cover and gasket when i replaced the head. Thanks again for the help though! anyone else know anything? if i have a cracked block would that be doiing this? i checked compression and all seems fine? im lost!
Old Mar 12, 2006 | 10:55 AM
BruceTS's Avatar
Did you check to see if your block was warped
Have you pressure tested the the cooling system, if it doesn't hold pressure, you can check to see if it's leaking into the cylinders by pulling the sparkplugs and stuffing strips of cloth down to see if they get wet.
ladybugRC
458
Aug 21, 2020 10:41 AM
LittleUgly
15
Jan 2, 2020 01:30 PM
wberry85
May 17, 2016 05:45 PM
alexcarey
Oct 14, 2015 06:05 PM
kcaudill
Oct 10, 2015 02:39 PM
