control arm needs replacing I have a few questions.
Old Dec 31, 2009 | 06:30 AM
1160049's Avatar
Guys I have a 92 Toyota 4x4 truck and the passenger’s side control arm needs replacing. I have a few questions.
The back of the arm is rusted out and I want to fix this before it turns into a mess.
My plan is to get two good used lower arms and rebuild them, (blast, paint, bushings, ball joint) so the down time will be minimal as this is my daily driver. After replacing one arm the other will need to be adjusted for a front end aliment as that one is rusted I plan to cut them both out and put the two rebuilt ones in.
Can I get a grinder / recipitating saw between the bushing and the frame mount to cut the bolt?
Has anyone used the control arm bushing kit from ebay ?
http://cgi.ebay.com/ebaymotors/Front-A-Frame-Arm-Bushings-Toyota-Pickup-89-95_W0QQcmdZViewItemQQhashZitem20a49fbe02QQitemZ140 200885762QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAcces sories
Sway bar Link from ebay ?
http://cgi.ebay.com/ebaymotors/AC-Delco-SWAY-BAR-LINK-KIT-toyota-PICKUP-truck-94-93-92_W0QQcmdZViewItemQQhashZitem35a5d96049QQitemZ230 415753289QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAcces sories
The arms NEW from Toyota are 300 + 90 for a bushing + 50 for hard where per side so buying new is out. Is there an aftermarket company that sell them?
I am from Newfoundland Canada and rust is a MAJOR problem down here
Any suggestions?
Old Apr 28, 2013 | 06:39 PM
rj radar's Avatar
I have the same exact problem both arms really rusted all the hardware is basically gone, on the drivers side the peice of metal connecting the shock to the arm is broken so shock just hangs there. Have no clue how to approach getting them off?
What's the best way?
Old Apr 28, 2013 | 06:56 PM
a51young's Avatar
here is a link to the FSM online, at lease for 2nd gen 4runner
http://web.archive.org/web/200807310...es/repair.html
and I think this is what you're looking for
http://web.archive.org/web/201008152...s/uppersus.pdf
I did mine the other day, not rusted out, but the alignment shop said the bushings were bad and needed to be replaced, they seemed fine to me though. Taking the the lower control arm off isn't too bad with a lot of pb blaster sprayed on the cam bolts a few times over a few days before you go at it, and a nice breaker bar. If you are just swaping out the control arm, it shouldn't take too long, few hours or so depending on if you have the right tools, like a ball joint puller and stuff.
Old Apr 28, 2013 | 09:30 PM
aztoyman's Avatar
I grew up in the rust belt. Buffalo NY. I'm so glad I now live in Arizona. When I did my SAS my control arms looked so good I didn't want to throw them away. I had just put bushings on the uppers too. Just bought them from local auto parts store.
Couldn't give them away either. I may still have them? Check CL in the desert climates and see if you can find a deal.
EDIT: Checked and all I have is the uppers.
Old Apr 30, 2013 | 11:32 PM
rj radar's Avatar
hey thanks for the help, was able to locate to arms at a salvage yard for like $35 each and there in great shape.stoked.
now I just gotta install em'.
bigjstang
Jun 2, 2025 03:56 PM
kazuya2416
Apr 5, 2024 02:17 AM
coryc85
Sep 9, 2015 06:24 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
cyclist231
Jul 7, 2015 12:56 PM
