clutch job...
Old Nov 10, 2008 | 06:53 PM
sloRunner's Avatar
clutch job...
its time to do the clutch on my 95 runner. im looking for something around or under 200 for mostly road driving but some wheelin, what kind of aftermarket clutches are out there?
Old Nov 10, 2008 | 08:19 PM
85TurboRunner's Avatar
I've had good luck with my Marlin clutch. I do mostly on road with intermittent offroad use. Its not too stiff, feels pretty much stock. I have around 10k on it right now.
Old Nov 11, 2008 | 07:07 PM
soarerjzz30's Avatar
Exedy makes a good clutch. Like oem, made in japan. Check ebay.
Old Nov 12, 2008 | 05:19 AM
83's Avatar
83
LUK clutches are also supposed to be good; that's what I put in my truck. Kinda wish I had put a Marlin in, though, for the small price difference.
Old Nov 12, 2008 | 06:34 AM
trbizwiz's Avatar
I just finished my Marlin clutch install last night. I am amazed at the difference. My clutch sucked through. When comparing, the marlin clutch comes with Their spec clutch (better than stock with stock feel and life span) pressure plate, throw out bearing, pilot Bering, and alignment tool. Also a big marlin sticker, good for 25 ft lbs of torque, maybe even temporarily substitute for re gearing, well probably not. LOL
Anyway, besides that you probably should replace your rear main, and anything else leaking out the bottom of your ride. You will also need to have your flywheel resurfaced I got mine done at Oreillys for $30, they even shaved the infamous step back into the fly wheel.
Good luck.
Old Nov 13, 2008 | 06:44 PM
Jay351's Avatar
Marlin crawler - Get the heavy duty unit (1200ft-lbs of clamping force). Don't bother with the super heavy duty version...
Old Nov 14, 2008 | 07:45 PM
sloRunner's Avatar
i ordered the heavy duty clutch. i should be putting it in by next week...anything special i should know before this project?
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
