clutch engagement not good
Old Dec 25, 2014 | 08:09 AM
WODAYODA's Avatar
hey yall, got a 93 v6 pickup i bought a few months ago from an old lady and she said she had a new clutch installed but no paperwork to back it up, again very nice old lady, atleast 65, anywho, my clutch doesnt seem to do anything untill about the last inch of pedal :/ the truck can peel out, wheel in 4 low or high just like it should with no slipping at all... any ideas out there? master and slave cylinder dont seem to be leaking either.... any ideas would be much appreciated, thanks.
Old Dec 25, 2014 | 06:55 PM
jbtvt's Avatar
If the pedal is depressing significantly before it engages with the pushrod in the MC you can adjust the nut under the pedal to take up the slack.
Old Dec 26, 2014 | 05:31 AM
WODAYODA's Avatar
sounds like just what i need, i do trust the old lady that she put a new on in i just bet it was super cheap. sweet so push clutch in then tighten bolt or tighten with clutch out? thanks dude vermont eh? i grew up in Mass and New York state
Old Dec 26, 2014 | 12:26 PM
wyoming9's Avatar
Red face
Stick your head under there make sure the clutch bracket is not cracked .
Heck only 65 I wonder why she didn`t change it herself??
Old Dec 26, 2014 | 01:19 PM
WODAYODA's Avatar
clutch bracket is fine...
Old Dec 26, 2014 | 03:28 PM
zombie_stomp's Avatar
I did the same thing with a friend's truck a few weeks ago. Feared it needed a clutch, but turned out someone installed a master cylinder and didn't leave any slack in the rod. Adjusting some free play into it made it feel like a full clutch again.
You get in behind the clutch pedal, loosen the locking nut and adjust the rod so that you feel some play in the whole assembly before the master cylinder starts to receive any pressure. Should be some forward-back play.
Old Dec 27, 2014 | 12:34 PM
WODAYODA's Avatar
so heres the problem, any idea if i need this guy? ˟˟˟˟ is leaking all over the place hah any help always appreciated! heres a link to my facebook so you can see https://www.facebook.com/photo.php?f...type=3&theater
Old Dec 31, 2014 | 07:13 PM
WODAYODA's Avatar
zombie stomp, the rod into the master cylinder has some free play and the bracket is not cracked at all. also its been pretty cold here in co and when i start the truck in the morning and put it in neutral is makes a sliding/clicking noise really quick...
Old Jan 1, 2015 | 12:52 AM
jbtvt's Avatar
Adjust the pedal play as described in this video or bleed the system, you'll get it.
[YOUTUBE]
[/YOUTUBE]
Old Jan 1, 2015 | 04:53 PM
WODAYODA's Avatar
yea i think i need to bleed the system, the fluid in the res. is DIRTY
the1998sr5
15
Jul 14, 2020 08:35 PM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
the1998sr5
Jul 16, 2015 06:20 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
