Castrol edge or mobil 1
Old Jul 16, 2010 | 06:35 PM
cdpmtoy's Avatar
what do peeps think about castrol edge 0w20 or mobil1 0w20 for new trucks?
Old Jul 16, 2010 | 06:57 PM
Teuf's Avatar
Whatever makes you feel good. Some like Mobil others like Castrol.
Old Jul 16, 2010 | 06:58 PM
Teuf's Avatar
I used Castrol for many years, now I am using Valvoline.
Old Jul 18, 2010 | 06:46 AM
going4halfmillion's Avatar
Anything but Penzoil!!
Old Jul 18, 2010 | 08:03 AM
khat toy's Avatar
what!?!? pennzoil is the best oil on the market. it has the longest carbon chains of any non-synth oil on the market, ie- greater durability under high temp/pressure applications. still, not the best choice for newer trucks, which are designed to run on synth. for that, i always preferred castrol, personally, but based on their chemistry, they should be about equal in terms of performance
Old Jul 18, 2010 | 02:11 PM
dbcx's Avatar
you know about any oil unless you send it off and have it tested then there will be no question what your oil ans engine is doing. that simple
Old Jul 18, 2010 | 03:33 PM
Teuf's Avatar
HUH, say again?
Old Jul 18, 2010 | 03:53 PM
toyomoto's Avatar
Valvoline's good. Unless your running flat-tappet rocker arms (like the 20r,22r, and 22re) then its reccomended to use diesel oil because of the extra chemicles in the oil needed for diesel engines to help resist cam lobe and non roller rocker tappet wear. Also if your running an aftermarket cam you should be using race oil or adding some MOA in your system because of the zinc. Amsoil makes wounderful products to.
Old Jul 18, 2010 | 04:03 PM
Teuf's Avatar
So with a cam, say Rotella would be a good choice. Ge I wonder if its too late, 22 years and 270k later.
1uzRunner
63
Nov 10, 2018 03:58 PM
live4soccer7
May 11, 2016 06:52 PM
PureTacoma_Tundra
PureTacoma_Tundra
Sep 24, 2015 12:14 PM
_Nicco_
Sep 21, 2015 03:06 PM
gyroscope7
Sep 21, 2015 04:55 AM
