Cardone Reman AFM 22RE
Old May 10, 2008 | 03:27 AM
pcmentor's Avatar
I just got my Reman AFM for $176. I have tested the ohms and it goes from 85ohms to 650 ohms relatively smoothly. I am hoping when I hook it up the volts will be smooth too. My orig AFM started around 250 ohms then jumped to 1600 ohms at mid point then down to 550 ohms at full open. This new one goes down to 475 ohms at full open. I hope it works ok. Anyone who has got a new/reman AFM they can ohm/volt test please post. Thanks
Old May 14, 2008 | 06:43 PM
pcmentor's Avatar
Sent it back
I returned the Cardone AFM. It tested voltage the same as my existing one.
Old May 14, 2008 | 09:18 PM
anotherjeff's Avatar
You are fortunate that they took it back. Many stores have a no return policy on electrical parts.
Old May 15, 2008 | 07:34 AM
pcmentor's Avatar
Amazon.com
Old May 19, 2008 | 09:51 AM
dirtoyboy's Avatar
make sure the part numbers match exactly. If they dont, it will NOT work correctly
Old May 19, 2008 | 06:18 PM
pcmentor's Avatar
You know the black plastic where the part numbers are didn't match but Cardone had stamped the right number on the case. I am not sure what to think about this.
tobylab
Jan 18, 2016 07:06 PM
Zpd426
Jan 2, 2016 01:15 PM
RatOmeter
Oct 22, 2015 03:17 PM
crashburnoveride
Aug 28, 2015 09:20 PM
tobylab
Jul 12, 2015 12:53 PM
