A/C complete redo
Old Aug 18, 2013 | 05:39 PM
SandDamaged's Avatar
A/C complete redo
Ok so I've made the decision to reinstall all new A/C components in my 89 Pickup. But my decision now is to either use the original R12 or the current R134a. Also I have heard that R134a is being phased out soon.
R12 I've read is better at cooling but more expensive.
R134a is cheaper at the moment.
What's the better choice ?
Old Aug 18, 2013 | 11:08 PM
Opinions, wisdom, knowledge, all welcomed.
Old Aug 18, 2013 | 11:36 PM
wyoming9's Avatar
Red face
Well buy enough R12 to see you through the next couple of years then make up your mind
If they replace R134a it will need to be replaced with something that should be compatible
Old Aug 18, 2013 | 11:40 PM
Discombobulated's Avatar
Not much of an expert but r12 Like you said is expensive and hard to get, might stick with the 134 mine is ice cold and fine. Haven't heard much on the 134 being phased out though? Please do tell when or where you heard this?
Anyway whatever you decide it will be great except the power loss is pretty depressing but being cool it's worth it
Old Aug 18, 2013 | 11:53 PM
gigatech88's Avatar
It MIGHT be replaced with hsf or something 1234y.
I've taken many classes on it but it has yet to be implemented
R12 will always be colder than 134. Dependent upon where you live 12 is readily available. Take a class on it, get certified and it becomes alot cheaper over the counter. Or just retrofit to 134. In the long run 134 isv the way to go if you can't obtain the 12
mussy01
Dec 13, 2016 08:20 PM
punks_is_4x4
Aug 21, 2015 01:35 PM
Sarcazmo
Aug 15, 2015 08:22 PM
g3bill2
Aug 7, 2015 07:04 AM
bryan34w
Jul 6, 2015 05:53 PM
