Brand New 22R Engine. Sky-high compression.
Old May 18, 2016 | 02:40 AM
crjosh97's Avatar
I brought a 1994 22R Hilux 2 years ago with a new engine and reconditioned gearbox. I thought I'd give it a compression test (just for grins and giggles) and found that I got a reading of 210psi on all 4 cylinders. Should I be worried? The car runs great, im just curious as to why the compression is that high?
Old May 24, 2016 | 08:07 PM
moroza's Avatar
Modified? Had the head shaved or block decked without a thicker headgasket? No, I would not be worried regardless.
Old Jun 25, 2016 | 03:10 AM
cbr600rx7's Avatar
Carbon can cause high compression as well as other issues. The gauge could also be a few % off. 210psi would be roughly 10 to 1 compression. A stock 22RE would have roughly 9.4 to compression however if the motor has been bored or the head has been resurfaced this will make the compression higher.
likkleBIT
Diesel Swaps
46
May 20, 2017 05:17 AM
lfcarrion3
Apr 5, 2016 09:09 AM
22R88
Mar 23, 2016 03:30 AM
mussy01
Mar 21, 2016 04:35 AM
emy111
7
Mar 6, 2016 01:02 PM
