Braking Power?
Old Mar 23, 2007 | 08:19 AM
Yota Tony's Avatar
Braking Power?
So this is a question for all the earily solid axle guys.
How good are the factory solid axle front discs and rear drums at stopping a truck with 35-36" rubber? I can't imagine it being great but is it liveable.
I'm wondering if I should upgrade to V6 IFS calipers and FJ-60 Rotors now (I'm going to do pads and rotors but I'm not sure what my calipers are like) or are the stock brakes enough.
If I do upgrade the calipers I will be using a large master cylinder too.
Old Mar 23, 2007 | 08:20 AM
mastacox's Avatar
You're going to want as much braking power as you can get with 36" meats...
Old Mar 23, 2007 | 02:35 PM
CoedNaked's Avatar
Why go half-assed?
If you're gonna spend the $$$ to upgrade, why not upgrade to Tundra brakes? If you got a 16" rim or bigger it should be very feasible.
Old Mar 23, 2007 | 02:41 PM
mastacox's Avatar
I'm not sure that Tundra brakes work on older SFA rigs... I think the factory brakes "upgrade" for them is the V-6 IFS calipers.
Old Mar 23, 2007 | 03:01 PM
Bill's Avatar
Yes, you should upgrade now.
Alot of cars with 4 wheel discs are using the same sized rear brakes as SFA toyotas had on the front. Whch roughly means they won't cut it, especially with 36" tires.
The rotors and pads are the same cost, just find yourself a set of calipers and a bigger MC and you're set. You don't NEED the 1" V6 MC, the 13/16" 4cyl will do quite nicley, especially if you still have the smaller drums in the back.
Old Mar 23, 2007 | 03:18 PM
Elvota's Avatar
I'd upgrade the front to the V6/ FJ discs and then do the rear as well.
https://www.yotatech.com/forums/f116/rear-disc-swap-107749/
I don't have 36's, but I stop no problem with my 35's. Wouldn't even think twice about upgrading to 37's and still stopping with confidence.
I had already upgraded the front with the V6/ FJ discs when I did my SAS.
Old Mar 23, 2007 | 07:00 PM
Yota Tony's Avatar
I'm not ready to do the rear discs yet. I want to put an IFS rear out back with FROR's Full Floater kit, that's gonna be a while.
The front should hopefully improve it a lot, I don't daily the truck so.
As for the MC, I'm getting it used for a song so, why not?
Old Mar 23, 2007 | 07:38 PM
waskillywabbit's Avatar
Front will need wheel spacers to fit the calipers, at least 1.5 inches, in addition to the loaded V6 calipers and vented rotors.
Since the front is the majority of your braking. . . upgrade.
FROR full floater rocks as now the brake parts are all interchangeable if need be, along with all the other stuff.
I got all the parts too.
Old Mar 25, 2007 | 11:09 AM
Yota Tony's Avatar
My rims have 2" back spacing so I might be able to get away without spacers.
Jun 1, 2021 01:51 PM
terminator
Jul 27, 2015 07:13 PM
harrisdawg
Jul 26, 2015 09:42 AM
CanRunner
Jul 20, 2015 01:29 PM
Johntom240
7
Jul 13, 2015 12:18 AM
