View Poll Results: How much body lift is okay?
0", no how no way....
19
11.66%
1", if I really HAD to
37
22.70%
1"
27
16.56%
2"
48
29.45%
3"
28
17.18%
Any amount is okay
2.45%
Voters: 163. You may not vote on this poll
Body Lift
Old Feb 1, 2007 | 09:55 AM
  #61
tacoma728's Avatar
On my year of tacoma, there is a slight gap without a bodylift. You don't want to read a little further into it than that, pathetic.
Old Feb 1, 2007 | 09:57 AM
  #62
tacoma728's Avatar
If i recall wabbit, i didn't ask for your advice or your input on what i want or need to do with my truck. I was merely stating a fact.
Old Feb 1, 2007 | 10:02 AM
  #63
tacoma728's Avatar
I made it myself and installed it by myself in under 3 hours and there was nothing tedious about it. It was spacers and bolts. Easy. WabFab
I was referring to some people's horrible labor description of a bodylift. Read into this thread more. A lot of people make it sound like a frame off restoration.
Old Feb 1, 2007 | 10:28 AM
  #64
4Crawler's Avatar
Originally Posted by crackerjack
I havn't had the issues mentioned ie rolling body, and squeaks.
But still have drivers side tire rub when it's compressed maybe should have went with 3"
Squeaking associated with a body lift is typically due to one of two things. First, squeaking means that something is moving between the body and frame. You need to have motion to make sound and for motion to occur, there has to be insufficient clamping force on the body mount bolts. So check the tightness of the fasteners and that should take care of it:
- http://www.4crawler.com/4x4/ForSale/...ml#TorqueSpecs
Second cause (often tied in with the first cause) is using lift blocks made of a hard, brittle material, like extruded fiberglass. Harder materials do not compress and therefore if a bolt loosens just a tiny amount, the body mount is loose and can slip and slide and squeak. Furthermore, the brittle block material can wear away due to the friction and that makes is get looser still, and squeak more. A lift block made of a self-lubricating plastic like UHMW or similar material can really help here. First the material is slightly compliant meaning it compresses just a little as the bolts are tightened. If they loosen a little, the material expands and the joint remains tight. And even if there is motion, the self-lubricating material won't squeak and won't wear away like a harder, brittle material will:
- http://www.4crawler.com/4x4/ForSale/...html#Materials
I pulled my 3" UHMW lift blocks out a few years ago (installed in 2000) and found no signs of wear (the tiny machining marks were still visible on the faces) and I have had no squeaking in all those years.
Old Feb 1, 2007 | 12:07 PM
  #65
Yota Tony's Avatar
I'm anti-body lift.
Coming from the Jeep world I see tons of people running 3" BL and it looks horrid. Most time it's for tire clearance. Tire clearance? That's what the sawzall and BFH are for.
I might do a 1" on my Yota cause 1 or 2 of my mounts are worn out and finding some stuck replacements might be a bitch.
Old Feb 1, 2007 | 12:19 PM
  #66
Kyle95sr5's Avatar
You posted your 2 cent and he posted his. Have some respect for the MUCH MORE knowledgable elders. If you want to continue to bicker about it, I think you came to the wrong site. TTORA and PIRATE would love to have you.
By the way, I LOOOVVEEE your euro tails and flame glow guages
Old Feb 1, 2007 | 10:52 PM
  #67
Numbchux's Avatar
Originally Posted by Yota Tony
I'm anti-body lift.
who cares what it looks like. if you're worried about looks, you're the perfect candidate for a body lift and some rubber skirts to cover the gap.
a buddy of mine bought a YJ that was built to be a mall crawler. so it really didn't have enough lift for the tires to flex. so, options were, SOA, smaller tires, or body lift. yea, he did the body lift. they still rub, but he got a crapload of flex out of it, for less than $100.
it's even better on a yota, because it allows a drivetrain lift too!!
tacoma728.....relax. you gave your $.02, and we gave ours. that's how this works.
Old Feb 2, 2007 | 06:45 AM
  #68
Yota Tony's Avatar
You don't need a 3" BL do do a flat skid on a Jeep.
1" BL and some cutting will do.
Anyhow, if I can find stock mounts for a good choice, I'll get them.
Old Feb 2, 2007 | 09:51 AM
  #69
tacoma728's Avatar
Well, my apologies, but I won't sway on the bodylift subject.
Thanks Kyle for your comments.
Old Feb 2, 2007 | 12:01 PM
  #70
Numbchux's Avatar
if you're talking about the rubber bushings...2 things
a body lift doesn't replace them, only adds to them, so if they're shot, you'll still need to get new ones
and www.4crawler.com has poly ones I believe. might be perfect for you.
Old Feb 2, 2007 | 12:18 PM
  #71
Yota Tony's Avatar
It is the rubber bushing, thanks!
Old Feb 2, 2007 | 12:27 PM
  #72
Kyle95sr5's Avatar
Your opinion is welcome. Everyone has differnet ones so naturally there is gonna be some conflict. Just don't insult the elders, they started this site and have kept it running as long as it has.
Im just messing with ya man. All in good fun.
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
upongame619
Aug 1, 2015 12:12 AM
Cabell
Jul 24, 2015 12:14 PM
Backcountry411
Jul 24, 2015 08:06 AM
