block cracked
Old Apr 12, 2007 | 03:37 PM
tampabayota's Avatar
block cracked
how would a cracked block run. would i see any evidence of it. what should i look for
Old Apr 12, 2007 | 03:40 PM
Knuckles's Avatar
Run would it? I know not
would a cracked block even be operational?
Old Apr 12, 2007 | 03:47 PM
pruney81's Avatar
I would say it would run extremely poorly if at all.
Old Apr 12, 2007 | 09:27 PM
TechWrench's Avatar
It depends on where the crack is.
Old Apr 12, 2007 | 09:38 PM
91TPU's Avatar
depends on the crack...it would run not so good tho, best guess would be as if you had air in the cooling system
Old Apr 12, 2007 | 10:28 PM
chopitrakeit's Avatar
Similar symptoms to a bad HG:
Air/combustion gas in coolant, oil in coolant, coolant in oil, fouled plugs, white exhaust or any combination of above.
A frozen block due to lack of antifreeze will leak coolant but the frost plugs should pop out before that happens if they are not rusted in solid.
What makes you think the block is cracked vs a bad HG?
Old Apr 13, 2007 | 06:50 AM
i dont think its cracked i think my timing cover has hole in it .the oil was black the top of the valve cover was foamy brown, i think colant was spraying up there
_Nicco_
Sep 21, 2015 03:06 PM
LotOMiles
Sep 14, 2015 11:45 PM
joeynational
Sep 5, 2015 01:54 PM
viesail
Sep 5, 2015 04:23 AM
pplusent
Sep 2, 2015 11:56 PM
