best rust paint?
Old Feb 21, 2008 | 09:48 AM
isaac338's Avatar
best rust paint?
i painted my driveshaft with tremclad (rustoleum) a while ago, and the rust is already showing through. study break is next week and i was thinking of flapwheeling the frame and painting it, but not if it's just gonna rust through right away.
what's the best paint to use that'll stop rust from forming underneath? POR15 is good, probably, but too expensive for me. does that rubberized undercoat stuff stop rust well?
thanks for any tips.
Old Feb 21, 2008 | 09:58 AM
WSUWESTON's Avatar
If you remove all the existing rust them rustoleum works well. Did you remove the exisitng rust before you painted it? I like the bedliner stuff, but once again it takes a lot of prep work and is about as expensive as POR15.
Old Feb 21, 2008 | 10:47 AM
YM13's Avatar
I have some stuff that i got from K-Mart i forgot the name it was like Kryola or something i dunno, but it said it converts the rust chemically and paints over it so it doesn't grow and new rust doesn't come in...i'll try and find the name
Old Feb 21, 2008 | 11:39 AM
isaac338's Avatar
yeah, i flap disced the whole shaft to bare metal. i'm thinking that my rustoleum problem might be from using a spray bomb, and only doing two or three coats. that's a pretty thin layer of paint. i may have had better results from brushing it on.
i still have black rustoleum lying around so i'll give that a shot on my frame - if it rusts, i'll try something else
Old Feb 21, 2008 | 12:07 PM
WSUWESTON's Avatar
YM is correct, there is a spray on rust converter. I have used it, but can't tell ya if it did anything or not
Old Feb 21, 2008 | 12:21 PM
isaac338's Avatar
i used some of that on my door. i wirewheeled the real loose rust off, then hit it with the rust converter spray (from rust check), then painted over it with some black spray bomb (no idea what brand). that was in the fall and there's already rust coming through.
Old Feb 21, 2008 | 12:49 PM
zlathim's Avatar
Do you mean Krylon?
Swampwalker
Oct 12, 2015 09:49 AM
Obmi
Sep 10, 2015 03:36 AM
86 87 4Runners
Sep 5, 2015 06:02 AM
86 87 4Runners
Sep 2, 2015 03:54 AM
