Bed Liners Spray on or Roll-on???
Old Mar 14, 2007 | 10:33 PM
91muddog's Avatar
Question Bed Liners Spray on or Roll-on???
im looking to remove my old plastic toyota bedliner. im thinking about getting a spray on bedliner put on. does anyone know how much it would cost??
what about rool-on bed liners? are they any good?
Old Mar 14, 2007 | 10:42 PM
HUTCHSTACO's Avatar
roll on's are not as good imo...about 350 - 400 to do yur truck most places for a spray in
Old Mar 14, 2007 | 10:43 PM
Nic's Avatar
Nic
Don't know for sure, but I think spray ons are about $400.00 and up. You might want to shop around to see what the prices are in your area. Just like everything else, there are differences in who does it. I would have mine done at a place that does it exclusively, and not a place that just does it on the side. That way you can be somewhat confident they know what they are doing. Also, if the place that does it says they cannot do over the rail bed liners, they probably aren't that good IMO. Mine came with a spray on from the previous owner and I like it.
I would not be confident in my abilities to do a roll on job, but I have read that some have had good luck with it.
Old Mar 14, 2007 | 10:47 PM
HUTCHSTACO's Avatar
linex is tough...rhino is a little softer...what do you plan to haul
Old Mar 14, 2007 | 10:52 PM
RadRacer'86's Avatar
great thread
https://www.yotatech.com/forums/show...=DIY+bed+liner
Old Mar 15, 2007 | 06:04 AM
Yota Tony's Avatar
What info do you have to back this up?
I did a roll on bed liner in my old Jeep. Used Herculiner and couldn't be happier with how it turned out.
The trick with these roll on bed liners is prep work. You have to put in the time to prep the floors or bed properly. If you don't it comes out like arse.
I've got 3 vehicles to do this year should it ever get warm enough. 1 is my Toyota's interior (which I'll take pics and post about). The other 2 are Jeeps, one is my gf's and the other belongs to a friend.
Here's some finished shots of my old Heep. I spent about 2.5hrs just on prepping the floors.
Old Mar 15, 2007 | 06:31 AM
4x4spaz's Avatar
I used Herculiner on my truck bed. I'm really happy with it. It has held up real well and was relatively easy to apply. The key as mentioned before is prep work. For more info look on my buildup. https://www.yotatech.com/forums/f197/4x4spazs-1983-pickup-build-up-thread-91282/
Old Mar 15, 2007 | 06:45 AM
jagger_snitt's Avatar
I agree with the above, Hurculiner all the way. $89.99 for a gallon.
I can't justify paying $$$$ for Line-X or Line-X style spray ons when I can get almost identical results with Hurculiner. Hurculiner doesn't have as smooth a texture as line-X but that could probably be changed depending on how you apply it. The hardest part is the prep work. It is worth it though.
Nothing makes you feel more satisfied than doing something yourself.
Old Mar 15, 2007 | 09:03 AM
Yota Tony's Avatar
Personally I like the texture of the Herculiner, things don't slide around as easily.
You can thin it though so it won't be as texturized.
I8URSVT
Mar 2, 2021 06:23 AM
justdifferentials
14
Jun 11, 2017 08:36 PM
ToyotaMD
Nov 9, 2015 11:53 AM
the_supernerd
Oct 1, 2015 09:20 PM
87SR5justin
Sep 29, 2015 02:50 PM
