Anyone Used Monstaliner??
Old Feb 9, 2010 | 12:18 PM
FieroGTdude's Avatar
Anyone ever used monstaliner. They have an add in the banner of the fourms. Is it any good? Looks like a good product.
http://www.monstaliner.com
Old Feb 9, 2010 | 12:22 PM
874runnersr5's Avatar
I would go for Por15
Old Feb 9, 2010 | 01:14 PM
jrobertson4runnner's Avatar
no, but I have used Duplicolor's roll-on liner. It works pretty well, but you have to get it the right thickness. I need to redo part of my interior because I didn't get it thick enough. I imagine Monstaliner, Herculiner, Duplicolor, etc are all gonna be similar.
Old Feb 9, 2010 | 01:16 PM
Im also thinkin about doin the lower halves of my doors with the spray version of the same stuff. you can get it at auto zone fairly cheap. I like the spray because it is flat versus shiny.
Old Feb 10, 2010 | 10:35 AM
Yeah I was thinking of doing my bumpers with it. Seems like it would hold up good.
Old Feb 10, 2010 | 12:20 PM
I have heard that it might cause stuff to rust under it, but i doubt it. if you use it to "stop" current rust, then maybe, but otherwise, i don't really think so.
Old Feb 11, 2010 | 12:41 PM
It's got to be better than the paint on it now. I dont think it will be a problem as long as I clean any rust off thats there now.
Old Feb 11, 2010 | 12:50 PM
yeah, my thoughts exactly. I think it would look really cool, and it would provide a little extra protection from rocks and stuff.
Old Feb 11, 2010 | 02:09 PM
Thats my problem now. I painted it with VHT epoxy black and that crap is chiping like crazy.
Old Feb 11, 2010 | 02:17 PM
something you might try, is the roll-on bedliner first, cuz you can get it ALOT thicker than the spray can, but you have to let it dry COMPLETELY, I mean let it sit for 2 days if you have to. Mostly it will be dry in about 12 hours, but leave it for a while if you can. only reason I say anything, is cuz i put a floor mat on my liner on my driver side while it was mostly dry, and it dried to my mat, pulling up a piece off the liner with it the first time i pulled it out to clean it.
Old Feb 11, 2010 | 02:21 PM
kiyobrown's Avatar
I just wonder if I put it in the cargo area UNDER the carpet if it will cut down on the exhaust/road noise enough to be worth it. It says its about the thickness of a dime.
Old Feb 11, 2010 | 02:37 PM
It might, it increases the amount of stuff between you and the road. I will say this, It doesn't do much on its own, I hear pretty much everything on the road. loud as all get out.
Old Feb 11, 2010 | 02:40 PM
I was thinking the same thing. It seems like it would cut the noise down quite a bit. I know they make some stuff called lizard skin for the firewall that is supposed to cut down on noise and I dont think its as thick as this the monstaliner.
FieroGTdude
Oct 19, 2016 07:23 PM
mshriver
9
Jul 22, 2015 03:25 PM
406dru
Apr 17, 2014 05:14 AM
FieroGTdude
Mar 26, 2011 02:16 PM
