Anyone Used Monstaliner??
Anyone ever used monstaliner. They have an add in the banner of the fourms. Is it any good? Looks like a good product.
http://www.monstaliner.com
no, but I have used Duplicolor's roll-on liner. It works pretty well, but you have to get it the right thickness. I need to redo part of my interior because I didn't get it thick enough. I imagine Monstaliner, Herculiner, Duplicolor, etc are all gonna be similar.
Im also thinkin about doin the lower halves of my doors with the spray version of the same stuff. you can get it at auto zone fairly cheap. I like the spray because it is flat versus shiny.
something you might try, is the roll-on bedliner first, cuz you can get it ALOT thicker than the spray can, but you have to let it dry COMPLETELY, I mean let it sit for 2 days if you have to. Mostly it will be dry in about 12 hours, but leave it for a while if you can. only reason I say anything, is cuz i put a floor mat on my liner on my driver side while it was mostly dry, and it dried to my mat, pulling up a piece off the liner with it the first time i pulled it out to clean it.
I was thinking the same thing. It seems like it would cut the noise down quite a bit. I know they make some stuff called lizard skin for the firewall that is supposed to cut down on noise and I dont think its as thick as this the monstaliner.
31x1050x15, good, herculiner, interior, liberators, lights, monstaliner, offroad, red, road, sound, tech, uniroyal, walmart, yota
