anybody use foam for filling frame?
Old Jul 14, 2006 | 06:58 PM
GrizzlyNC's Avatar
Originally Posted by firemedic
I don't doubt that the foam itself will be waterproof, the problem is that I don't think you will get a perfect waterproof seal, from the foam, to the metal of the frame. It might look like it seals OK, but just a little bit of water seeps in there and it will take forever to evaporate/dry, thereby actually increasing the chance for rust IMHO.
I completely agree with firemedic on this, also keep in mind with all the exposure to mud, dirt, salt, etc. even if the foam is "Weatherproof" if dirt gets lodged between the foam or gets into an area that the foam didnt reach it will be the dirt/salt etc. that retains the moisture and as firemedic stated it would take forever for it to evaporate.. If it were me and my truck I'd probably not do it. Just a personal opinion..
Old Jul 14, 2006 | 08:46 PM
CyMoN's Avatar
i work in construction and use the poly foam all the time some resist water but that is only the outside layer if you cut into some of these foams they will soak water up like a sponge. There are some newer brands of fast foams that are closed cell .i had thought about this before but i am glad i did not use foam because theres no way of knowing for sure if you have a airtight seal I say don't
Old Jul 17, 2006 | 07:30 PM
Ringmaster's Avatar
Originally Posted by Sporin
I use bar & chain oil as an undercoating (GREAT stuff) and I've often wondered if I could figure out a way to spray it into the frame, all the way, down deep, full coverage, really coat the inside with the stuff.
Any ideas that won't make a GIGANTIC mess?
A small 2 gallon pump up weed sprayer might do the deed?
Old Jul 17, 2006 | 08:14 PM
hamstrungtaco's Avatar
if ur really concerned about corrosion inside the frame, one thing u could do is box off, plate up, or whatever parts with packets of silica gel inside with some type of brass threaded plug to relieve it, or if u have the technology, take the frame out and take it to a galvinizer, problem with that foam is once its in there, it aint coming out
Old Jul 18, 2006 | 04:21 AM
  #25
Sporin's Avatar
I actually found this suggestion online as well. In fact, it seems people like to warm the oil up and mix it with some melted parafin wax. Spray the frame while it's hot and it sticks and stays.
Probably going to give that a try this fall.
Old Jul 18, 2006 | 04:25 AM
  #26
maxpower_hd's Avatar
Originally Posted by Intrepid
It is funny, you never realize how many people are actually on here from up this way...until a rust thread comes around!
The problem with that is that your whole truck smells like deisel, not to mention that it probably smells as it burns off the exhaust and other hot parts. Plus, where do you do that that it doesn't make a nasty mess?
I was out by Ashburnham last Saturday for the Tyler motorcycle ride. I don't know if you happen to be one of the lucky people that got stuck waiting for 500 motorcycles to go by or not, but if you were I was one of them.
I wasn't there for the process. I'm sure it must of smelled when they applied it but it didn't smell when I saw it. If my memory serves, and there is no real reason it should, they used a weed or deck stain sprayer like mentioned above. I'm assumming they tried to steer clear of the exhaust.
How long has the foam been in your's? I would be leary about using it too only because I would be worried about it filling the frame 100%. Any gaps at all would be a place for water to get trapped. At least if it is hollow, it can drain and dry.
Old Jul 18, 2006 | 04:42 AM
  #27
hillbilly's Avatar
Many years ago, I remember my Dad pouring turpentine into the door panels/rocker panels and small areas of the fender/quarter panels of his '79 Jeep after cleaning them out. He'd catch the excess run off with small buckets under the drain holes. He did that annually for the first few years he owned it in hopes of preventing the notorious body rot the older Heeps were known for. It smelled like a mobile pine factory for a few weeks afterward, but the turpentine dried and coated everything with a pine tar type finish that was pretty darn tough. He drove that Cherokee for nearly 20 years without massive rot problems.
Old Jul 18, 2006 | 04:54 AM
  #28
Intrepid's Avatar
I was lucky enough to not get stuck waiting, thank god!
As far as the foam in my frame, I would not personally have done it, but it was in there when I bought the truck. It has been in there for the 9-10 months I have owned the truck. The frame is solid as far as I can tell from the outside, I am a bit nervous about the possibility of the inside rotting out though. Nothing I can do about it now though. Just keep the outside clean and hope it works.
Old Jul 18, 2006 | 05:11 AM
  #29
Mikey's Avatar
I'm not a fan of the foam thing either. Your going to have some scale and dirt inside the frame creating a barrier from letting the foam bond directly to the metal.
Have any of you guys checked out some products by eastwood. They have a really great paint called rust encapsulator that last much longer than rustoleum. much more pricey though. And they also have a rust inhibitor called anti rust that sets up like a wax. It reminds me of cosmolean, if any of you guys are gun fans. It smells like it but dries harder like a wax. I have used it and it works great. Makes things smell for a while though. MAKE SURE YOU DONT USE IT ABOVE YOUR EXHAUST! Man! I made that mistake and it smells for a good long time untill it melts off.
I never used the POR-15 although I heard that works great for preventing rust.
justdifferentials
14
Jun 11, 2017 08:36 PM
indawire
Nov 29, 2015 05:05 AM
gyroscope7
7
Sep 27, 2015 08:39 PM
eggens
Sep 5, 2015 12:16 AM
Badfish740
Sep 4, 2015 04:21 AM
