Affordable torque wrench for pinion preload?
Old Aug 6, 2008 | 04:14 PM
BigO's Avatar
I am getting ready to do some diff work, and I need to get a proper torque wrench. What are my options for an in/lb 1/4" torque wrench to measure pinion preload? Are there any more "affordable" than a Snap-on dial torque wrench at $300?
If that's what it take's then I will get it, but I am hoping there is a good alternative that is still good quality too.
Old Aug 6, 2008 | 05:11 PM
Adam F's Avatar
Harbor Freight, Craftsman, Northern Tools,
Rent one from AutoZone for free.
Old Aug 6, 2008 | 07:35 PM
tc's Avatar
tc
http://www.parktool.com/products/det...13&item=TW%2D1
$34.99 at Performance Bike
http://www.performancebike.com/shop/....cfm?SKU=11387
Old Aug 7, 2008 | 06:55 AM
dirtoyboy's Avatar
get a craftsman....just buy it once
Old Aug 7, 2008 | 01:56 PM
BigO's Avatar
Thanks for the suggestions, but don't I need a "visually indicating" torque wrench, such as a dial or beam-deflection, capable of measuring 5-16 in-lbs?
I could be wrong, because I have never rebuilt a 3rd before, but that is what I gather from reading the shop manual.
Something like that ParkTool torque wrench may be the ticket. Would a 0-60 in-lbs scale give me an accurate enough reading down low, or do I need someting with a smaller scale such as 0-30 in-lbs? Any other suggetions, or tricks for doing this without a specialty torque wrench?
Old Aug 7, 2008 | 02:21 PM
tc's Avatar
tc
Yes, you need a dial or beam type.
Zuk uses the Park one ... that's a good enough recommendation for me!
Old Aug 8, 2008 | 04:46 AM
GSGALLANT's Avatar
Yep. That parktool one mentioned above is the one I use. It works fine, and is priced right.
kawazx636
Oct 6, 2021 03:03 PM
Kamaloha
Oct 16, 2015 05:13 PM
Obmi
Oct 4, 2015 11:30 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
Odin
Sep 26, 2015 06:56 PM
