Adj air pressure switch
Old Dec 29, 2006 | 06:13 AM
AH64ID's Avatar
Does anyone know where you can get a 12v adj air pressure switch. I need one that is adjustible in the 20-50ish range.
Thanks
Old Dec 29, 2006 | 07:41 AM
Robinhood150's Avatar
You mean like a regulator? I think you'll just need to get a regulator from the hardware store and put it inline before your switch.
Old Dec 29, 2006 | 02:52 PM
AH64ID's Avatar
nope, a psi switch the opens/closes a circuit when you go above/below a specific psi...
Old Jan 3, 2007 | 04:24 AM
AH64ID's Avatar
Old Jan 3, 2007 | 04:58 AM
Adam F's Avatar
I've seen a bunch that are like 90-115psi, but never 20-50.
WAIT, here's one, but its 115vac, you could probably use a relay or something to make it work
http://www.surpluscenter.com/item.as...42&catname=air
http://www.streetpros.com/search.php...ssure%20switch
http://store.summitracing.com/egnsea...nresults=false
http://www.airride.com/productinfo/components.asp
http://www.airbagit-store.com/produc...t.asp&ID=95901
http://search.ebay.com/search/search...tSearch=Search
http://www.surpluscenter.com/sort.as...ssure%20switch
Old Jan 3, 2007 | 05:16 AM
AH64ID's Avatar
I need on that is adj in the 20-50 range, not 20 on 50 off... but thats for the info...
WATRD found this one, but its $$$... I dont need one that fancy.. .but so far its all anyone can seem to fine..
Doug4320
Mar 24, 2018 10:11 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
stock87yota
Jul 31, 2015 10:08 AM
calderp
Jul 27, 2015 09:58 AM
skoti89
Jul 8, 2015 12:05 AM
