3.4 Supercharger
Old Jan 2, 2007 | 01:18 PM
callmej75's Avatar
3.4 Supercharger
Anyone gotta diagram of one? I got a guy that wants his powder coated, but I'm not sure if there are internal seals that would get cooked in the 400* temps.
Old Jan 2, 2007 | 04:19 PM
rimpainter.com's Avatar
Does this help?
http://customtacos.com/tech/index.php?article=45
Old Jan 2, 2007 | 04:26 PM
callmej75's Avatar
Originally Posted by <96 Runner>
Actually I need a breakdown of the internals....just to see if there is any o-rings or seals that would cook and burn up while I powder coated it assembled. Thanks for the help though!
Old Jan 3, 2007 | 07:56 AM
mt_goat's Avatar
I would say it would have some seals in it since it holds oil (usually without leaking).
Also check out post # 12 here where Dick is talking about some plastic gears in there somewhere:
http://www.ttora.com/forum/showthread.php?t=54906
I'd say IMHO it would be a bad idea to bake it at 400 deg F
Old Jan 3, 2007 | 08:03 AM
callmej75's Avatar
Thats what I was telling the guy on TTORA before they deleted my thread...
Old Jan 3, 2007 | 08:08 AM
mastacox's Avatar
It seems it would be possible if it was disassembled/stripped to just the S/C body, but that would really suck if it were permanently damaged so don't take my word for it...
Old Jan 3, 2007 | 08:10 AM
callmej75's Avatar
Yep...I agree...the body would withstand the heat. Don't want to mess up $2,000 worth of good fun stuff! Gather my knowledge before I even consider it.
Old Jan 3, 2007 | 11:45 AM
MTL_4runner's Avatar
I agree, it most definately has seals on it. The needle bearings are all permanently greased which means you'll cook the grease on them for sure. The nose drive has a front seal which keeps the oil in. I would never put it through a powdercoating oven without disassembling it first......but that's just me. It might survive fine, but I wouldn't want to be the one to bet $2k on it.
Here's a good thread to show you what the insides look like:
https://www.yotatech.com/forums/f2/death-trd-s-c-94761/
Old Jan 3, 2007 | 11:51 AM
HaveBlue's Avatar
How hot does it get just sitting on top the engine?
callmej75's Avatar
https://www.yotatech.com/forums/showthread.php?t=94761
That helps! Thanks alot! I love YT...
Old Jan 3, 2007 | 12:43 PM
04 Rocko Taco's Avatar
a point that has been brought up before, and I dont know if gets to 400* but I would say it does get pretty warm. If you had one of those infared thermometers you could check it out.
Old Jan 3, 2007 | 12:47 PM
mastacox's Avatar
Well, I wouldn't think much hotter than 200*F... If I went driving around for quite a long time, and then poured water on the S/C body, it wouldn't boil... In fact most times I'm able to directly touch the supercharger's body even after driving around for some time.
Old Jan 3, 2007 | 02:03 PM
marko3xl3's Avatar
It's definately not a good idea. I could probably come up with many reasons why.
Actually, I am not even talking out of the blue, I already considered the idea and decided that when I do send mine out to be P/C'ed (way down the road) I'll do it when magnusen is rebuilding it and I'll have them 'lend' me the casting only once it's all disassembled. I am lucky I have the 1st/3rd gen, because I don't know how far you can strip the 2nd/4th gen if you wanted it a different color. It's probably possible, but much harder.
My 2c
Old Jan 3, 2007 | 02:08 PM
callmej75's Avatar
I don't PC anything assembled that has to do with automobile accessories or mechanicals....usually most of the stuff does have seals and require disassembly. Thanks for the inputs...an SC shell wouldn't be hard to do at all. Just gotta tape off the bottom so no PC or chemicals get into the inside of it.
Steven.m.paulk
Jun 7, 2020 10:45 AM
primordialbeast117
Dec 19, 2015 12:23 PM
White Stripe
Oct 6, 2015 10:47 AM
LCE_Performance
Oct 1, 2015 01:03 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
