22Re won't start (
Old Sep 10, 2017 | 04:17 PM
hookerpilot47's Avatar
Angry 22Re won't start (
Ladies and Gents,
short bio on this
driving home the other day this is what happens. Starts slower and after 10-15 minutes when pulling up to a stoplight and the clutch in the idle drops way off and is bairly hanging on and almost dies . After reving it up and keeping it going on the way home it began sputtering and hesitating and jumping with the accelerator in on position. After 10-15 minutes I pull into the gas station and it dies. Won't restart or attempt just all most like it's not getting fuel.
towed it home via a strap.
i just replaced the fuel filter and now it will won't start. Here is the video of t
Old Sep 10, 2017 | 05:41 PM
L5wolvesf's Avatar
Have you checked to see if you are getting fuel?
Old Sep 11, 2017 | 12:07 AM
wyoming9's Avatar
Red face
Run out of Gas ??
When you changed the fuel filter how much gas came out the line??
Have you jumped B+ to FP to bypass the AFM and Circuit opening relay ??
Might be the next step
Old Sep 11, 2017 | 01:02 PM
RAD4Runner's Avatar
Start with basics:
In order to go "VROOOM!" you must have Spark, Fuel, Air.
Got spark?
Got fuel? (like wyoming and L5wolvesf say^^^). Some of us decided that time is better spent installing this, than time spent guessing.
Got Air? (This is less likely to cause your symptoms but worth a look at.) Got crack on the intake between AFM and intake manifold? A break there would prevent AFM flap from opening.
Old Sep 11, 2017 | 04:54 PM
Got spark, fuel pump after I blocked the IAC in the air box the cold start spewed gas Ht dropp d off fast and no noise from the fuel pump. Update troubleshooting shows the fuel pump, don't make noise and not enough fuel pressure to push into injectors.
Bought a block I g plat set for the EGR so expect the blocking plate and the fuel pump to show up from Rock auto at the same time ..
Old Sep 11, 2017 | 04:55 PM
Originally Posted by wyoming9
Run out of Gas ??
not much came out, looks like I found the culprit the fuel pump in the tank.... your a huge help thank you.
Old Sep 11, 2017 | 04:57 PM
Start with basics:
Got spark?
like does anyone make a replacement for that garbage on that system so I can get rid of it? Any advice I do have a few tiny cracks but have sealed them up
any other advise
Old Sep 11, 2017 | 11:29 PM
wyoming9's Avatar
Red face
You might want to define Garbage on the system??
One can pretty often fabricate what is needed although it does tend to get expensive $$$$$$
I can`t see the reason for deleting the EGR I never have but to each there own .
I can`t see any real benefit on such a low horsepower engine in a heavy vehicle
Old Sep 12, 2017 | 08:27 AM
Thanks much for your help, lots of lines and parts that are hard to get its all and makes it easier to diagnose is all for me
