22re engine miss
Old May 30, 2010 | 05:50 AM
reman's Avatar
22re engine miss
'93 model p/u, 22re 2wd, 5 spd., 230,000 miles has developed engine miss recently. Occurs between 2500-3000 rpm in any gear. Idles and runs perfect up to that speed, then gets better at higher rpm but does not completely go away. New head and timing set 5000 miles ago. New injectors, fuel filter, plugs, cap, rotor, Toyota wires, throttle position sensor, O2 sensor, air flow meter. Plug gap and timing are correct. Disconnected aftermarket tach, not the problem. Disconnected vacuum hose to EGR valve and drove it, problem still exists. Anyone have any ideas on this one? Thanks in advance.
Old May 30, 2010 | 08:35 AM
runner88's Avatar
A buddy had the exact same problem. Turned out to be a gasket between the EGR valve. Its a metal ring thats probably a dealer only item. He was able to pound it out slightly and re-use it. Post back if it works. Good luck!
Old May 30, 2010 | 08:52 AM
reman's Avatar
Well, I'll check that out. I did install all new gaskets at the time of the head rebuild, but I'll check anyway to make sure. Thanks.
Old May 30, 2010 | 10:09 AM
reman's Avatar
Could find no problem EGR related. Any other ideas, anyone?
icentropy
Sep 16, 2020 02:47 PM
Colington
Mar 8, 2020 09:51 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
steve miller
Oct 10, 2015 01:40 AM
crashburnoveride
Aug 28, 2015 09:20 PM
