22r idleing
Old Aug 8, 2010 | 05:14 PM
yota38s's Avatar
22r idleing
ok i have 1987 pick up.. i just put motor in .. its runs pretty good but will not idle when you first start it ... but once it warms up it idles ok.... i have a weber carb on it... i have new plugs,wires,cap,and rotor on it.... also the exhaust coming off the manifold to the exhaust does it have a metal gasket and a donut gasket? and you think i should put a manual choke on the carb for the cold mornings?
Old Aug 8, 2010 | 05:18 PM
xxxtreme22r's Avatar
Originally Posted by yota38s
will not idle when you first start it ... but once it warms up it idles ok.. and you think i should put a manual choke on the carb for the cold mornings?
there is your problem
you don't have a choke on it?
Old Aug 8, 2010 | 05:20 PM
85gijunk4x4's Avatar
yes!!! definitly put a choke on it lol.
Old Aug 8, 2010 | 05:59 PM
yota38s's Avatar
i guess it has an electrical choke? it may not be working ? im new to toyotas i dont know... where the manifold meets the exhaust does it have donut gaskets and a metal gasket?
Old Aug 9, 2010 | 04:29 AM
is there a single wire that goes to the passenger side of the carb? Do you have voltage there?
This is typical carburetor stuff, not exactly toyota related and the weber is definitely not factory.
Sorry can't help with the exhaust gasket as I have a header on my truck. Might want to look on toyotapartszone.com for some part numbers and diagrams. And see if you can find what it has from that.
Autozone.com might also be able to tell you what is there.
Old Aug 9, 2010 | 07:09 AM
yota38s's Avatar
ok ill check the voltage on that.... have any of yal ever tryed the manual choke?
Blamalam
Mar 12, 2022 07:34 AM
dumpster84
Apr 30, 2016 06:03 AM
87blyota
Aug 23, 2015 03:57 AM
Fakayayou
Aug 9, 2015 12:47 AM
kyletbert
Jul 17, 2015 11:39 AM
