Sponsored by: CARiD
zuk mod question
Old Feb 18, 2013 | 07:19 AM
Pope&YoungYota's Avatar
zuk mod question
Think I am going to do the zuk mod to my 90 pickup longbed. I have 3'' blocks back there now and hate them. My question is, What length springs would I need to keep it about the same height. The 12 or 14''? Also is there anyway to tell if my torsion bars have been adjusted by PO? Thanks again.
Old Feb 18, 2013 | 07:32 AM
toyota4x4907's Avatar
Cant comment about the ZUK Mod, but if the front doesnt have any bracket lift or ball-joint spacers, then if the lower control arms are parallel or almost parallel to the ground, the T-bars have probably never been cranked. Or just a little bit.
Old Feb 18, 2013 | 07:50 AM
cman1's Avatar
i used the 5"coil 13"tall black magic 100lb springs for 3" of lift on my 1980 longbed.i fit sits even with three inch blocks,its probably been cranked.
[IMG][/IMG]
Old Feb 18, 2013 | 08:07 AM
it sits higher in rear right now.
Old Feb 18, 2013 | 08:59 AM
JohnnyCanuck's Avatar
I have 4" blocks in the rear, I bought the 100lb 14" black magic springs, should do the trick.
Old Feb 18, 2013 | 11:38 AM
derockus's Avatar
I used Jeep TJ front springs for my ZUK. They are 14" to start. I cut mine down to 12". You could try with 14", see how it looks, then cut them down if needed. You could cut the black magics too. FYI cutting the springs changes the spring rate (makes em stiffer). My cut TJ springs make the rear pretty stiff when empty but it can handle a load without sagging.
Old Feb 18, 2013 | 06:23 PM
ZUK's Avatar
ZUK
I agree.... specify 100 pounders when ordering 2 of them. You'll like the soft ride also
http://www.ebay.com/itm/NEW-RACING-C...125492&vxp=mtr
Old Feb 18, 2013 | 08:44 PM
cman1's Avatar
Zuk to the rescue!!!
Old Feb 20, 2013 | 02:12 PM
If I install a 4'' bracket lift, would the 14's still work for 4'' in rear?
Old Feb 20, 2013 | 06:01 PM
ZUK's Avatar
ZUK
Yes.....but I'd up it with the 14 x 125 pounders just for that extra lift. They are still soft riding coils.
Old Feb 21, 2013 | 03:10 AM
Thanks alot guys!
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
Massmayhem247
Jul 18, 2015 05:46 AM
icentropy
Jul 11, 2015 07:21 AM
Nickdigg
Jul 7, 2015 06:04 AM
