Sponsored by: CARiD
Wind up
Old Mar 13, 2007 | 12:59 PM
Diesel Dave's Avatar
Question Wind up
HELP!
Has anybody thoughts on how/why my hilux pickup seems to be suffering from axle wind up even though its in H2 and the front hubs are unlocked.
Dave.
Old Mar 13, 2007 | 01:07 PM
MudHippy's Avatar
If you have worn out springs in the rear, or if something has wiggled loose, that would cause the axle to want to wind(wrap). Check for loose u-bolts or other connections at the rear axle, also check the bushings. You don't have over-size tires, do you?
Old Mar 13, 2007 | 01:53 PM
Hello Mudhippy,
Ive got a broken rear leaf spring on the passenger side, the axle only starts to get wound up after 5 miles or so, would this be the cause then.
Thanks for your help mate I appreciate it!
Dave
Old Mar 13, 2007 | 02:05 PM
MudHippy's Avatar
Yes, that would do it for sure. The spring that's suffering would be a little less stiff, it doesn't take much. It's hard on your driveshaft u-joints and the other bearings invovled. So you should try to get it fixed as soon as you can, before it wreaks to much havoc.
Old Mar 13, 2007 | 02:42 PM
I wish Id posted earlier mate, its in the repair shop now! they`ve told me the rear diffs knacked, I just could`nt figure out what caused it, been running around a few weeks now with the broken spring.
Thanks again.
Old Mar 15, 2007 | 09:23 AM
Ow, MudHippy,
Garage just phoned, no oil in the back axle!
Old Mar 15, 2007 | 09:44 AM
MudHippy's Avatar
That's never a good thing. If it's toasted the parts can be swapped in from a junker, if there's one available. A shop will charge a pretty penny putting it in for you. So, if you have any wrenching skills you might do the job yourself. It's relatively simple to do a rear axle, as a whole, or just the gears (3rd member).
Old Mar 15, 2007 | 07:56 PM
Its had oil put in and they reckon theres a bit of a whine, but not too bad.
They are changing the spring, so it`ll have to do for now.
I`m too old & bone idle to do repairs now mate.
51 I feel more like 81
Blamalam
Mar 12, 2022 07:34 AM
Socerlover
Sep 11, 2015 01:31 PM
anndel
Sep 10, 2015 08:50 AM
trailgoat
Aug 13, 2015 05:54 PM
terminator
Jul 27, 2015 07:13 PM
