Sponsored by: CARiD
Where can I get good Head Gasket?
Old Sep 10, 2009 | 06:52 PM
partypeepers's Avatar
Does anyone know where i can buy online some good head gasket? I dont want to buy some not good rated ones then have to change them in a couple of years? Well now that Im here I have a question. Ok my truck runs low on coolant everytime I drive it, i have to keep refilling up my radiator, I dont see any white smoke out of the exhaust I do see some like little spits of water coming out though but not alot, ok a mechanic looked at the oil cap and there was white stuff underneath it and said its my head or head gasket, is this true? does any one have like a manual where it shows how to replace this? so im gonna need the whole head set gasket kit. whats a good one I can get? thank you very much its a 1986 toyota pickup 4wd 22re efi
Old Sep 10, 2009 | 07:21 PM
nhughes's Avatar
Bubbles in your coolant too?
Old Sep 10, 2009 | 08:09 PM
myyota's Avatar
www.engnbldr.com , he has good parts and service.
Old Sep 11, 2009 | 05:28 AM
83's Avatar
83
x2 on engnbldr.com, but you'd better make sure it's really the head gasket. A little milky residue on the oil cap is not uncommon, and is a silly way to diagnose a headgasket issue. There are real tests to determine that.
Old Sep 11, 2009 | 06:22 AM
the oil cap is not milky its like white inside the cap. And i have checked for leaks and I cant find any leaks and when i checked my oil there appeared to be more oil or water I would say, The dipstick was full when i would pull it out.
Old Sep 11, 2009 | 06:23 AM
Well I cant tell if theres bubbles or not cause its to hot to open it butthe first time I noticed it overheated the reservoir was boiling and water was dripping from there. What test can I perform to see if its a head gasket?
Old Sep 11, 2009 | 06:31 AM
i went on that engbuilder and i couldnt find the head set gasket? Whats it called? i clicked on build a kit 85-95
Old Sep 11, 2009 | 06:33 AM
snobdds's Avatar
You have to do a compression test on all cylendars (sp?) to see if one or all are showing low compression. That would be the best way to see if you have a blown head gasket.
Your local autoparts store should have the test.
Old Sep 11, 2009 | 08:34 AM
83's Avatar
83
Well if the dipstick looks like chocolate milk and is overfull, then yes, you have water in your coolant, and if it's been like that for a while and you've been driving it around that way, you should probably be looking at a full rebuild kit, because coolant will destroy your bearings.
Old Sep 11, 2009 | 08:57 AM
22REw/HP's Avatar
lets not forget about the real japanese head gaskets, there are other products other than chinese!!!!
http://www.22re.com/main/toy/toy.asp
Old Sep 11, 2009 | 10:09 AM
fillsrunner4's Avatar
Just go to Napa
Old Sep 11, 2009 | 01:20 PM
I was reading these instructions on removing the head. It didnt mention anything about removing the Timing cover. Can this be done without removing the timing cover?
Old Sep 13, 2009 | 03:00 PM
mistreatedtoys's Avatar
Hows the timing chain and guides. If the guides were bad the chain could have worn a small hole in the cover letting coolant get in under pressure. problem is to do the cover correctly you should remove the head.
Old Sep 13, 2009 | 09:39 PM
Jay351's Avatar
Originally Posted by Buhundred
OEM Toyota head gasket.
x2!!!
this is one gasket I would always go toyota!
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
smiley52
Jul 11, 2015 05:16 AM
87blyota
Jul 10, 2015 04:31 AM
88runnergomas
Jul 9, 2015 01:12 PM
