Sponsored by: CARiD
What Transmission Fits
Old Oct 12, 2013 | 12:18 PM
Greasytooth21's Avatar
Hey all, I've searched and can't find a definitive answer so here it goes: I have a 89 pickup 22re 4x4. I have been searching my local craigslist for used transmissions and transfer cases. I know most of them post 83 are 25.5 inches long. I believe mine is a w-56 21 spline. My question is will any post 83 transmission bolt up to my 22re with little modification? I know there are multiple transmission codes for the same years. Any clarification would be greatly appreciated.
Old Oct 12, 2013 | 12:27 PM
Stetson_md's Avatar
As far as i know Any tranny that was behind a 22r/re should bolt to your motor
G52 and w56's won't need any mods others might need the t
Hole in the floor board made bigger or need longer/shorter drive shafts
Old Oct 12, 2013 | 12:43 PM
Which brings me to my follow up question; With all the different transmissions for toyotas how do I determine a w56 from a g52/54 ect?
Old Oct 12, 2013 | 01:01 PM
Stetson_md's Avatar
The easiest way I know of is the shift pattern on a w56 the shifters will touch (or almost touch) in 2hi and reverse on a
G52 its 4low and 2nd. No idea about a g54 or if the pattern of a w56 was different between the types (type a, b,c, d)
Old Oct 12, 2013 | 03:19 PM
rokblok's Avatar
Check Marlins site for transmission bible. It doesn't tell you exactly how to identify it unless you look at front bearing numbers I believe. So far as I know, there isn't a real easy way to identify them externally.
Old Oct 12, 2013 | 04:48 PM
Checked marlins site it has allot of great info. Thats how I found there were tons of transmissions in toyotas! I just want to get mine replaced I'm tired of grinding third gear and no speedo (speedo gear lasts a day) but I don't have the cash for marlins new units, pickings are slim in Tucson.
Old Oct 12, 2013 | 05:43 PM
rokblok's Avatar
The G series are basically early W series from what I can gather. Anything that was behind a 22R or RE will bolt up. The differences being top shift transfer case or forward shift transfer case (which would tell you where it may need a shifter hole opened up in the floor); and wheelbase, which would only affect driveline lengths.
Old Oct 12, 2013 | 06:23 PM
Stetson_md's Avatar
This guy is parting out a 83 with a 85 tranny $350 for the trans should be a g52http://phoenix.craigslist.org/wvl/pts/4126125311.html
Old Oct 12, 2013 | 06:41 PM
rokblok's Avatar
If that trans is an 85 and was originally behind that 22RE, it should be a W56A.
Dependent on build date and engine also... It could be either a G52 or G54...
Old Oct 12, 2013 | 07:01 PM
Thanks for all the help guys!
Old Oct 12, 2013 | 08:00 PM
Stetson_md's Avatar
Yeah your right I didn't notice it was a re
Old Nov 8, 2013 | 12:54 PM
Dongskie's Avatar
I have a 2C diesel engine and mates with a G52 RWD manual tranny, what Automatic tranny will fit my 2C engine?
Thanks all!
Old Nov 9, 2013 | 04:20 AM
Stetson_md's Avatar
Any of the ones behind a 22r/re will probably bolt up but there's a lot of other parts you need
Old Nov 9, 2013 | 04:38 AM
bone collector's Avatar
http://www.4x4wire.com/toyota/faq/parts/
Old Nov 11, 2013 | 12:41 PM
Dongskie's Avatar
Thank you guys!
I was also told that the 7K-E, 2L auto trannies will fit.
Will explore.
crammit442
7
Nov 29, 2017 12:30 PM
BeMiceElf
Oct 10, 2015 09:40 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
Tigbucket
Jul 30, 2015 07:29 PM
yourrealdad
Jul 29, 2015 11:08 AM
