Sponsored by: CARiD
what kind of tranny do i have
Old Apr 21, 2009 | 07:39 PM
justen24's Avatar
i have an 85 toyota truck i was wondering how i go about figuring out what kind of tranny i have any help would be greatly welcomed
Old Apr 21, 2009 | 07:55 PM
whokrz's Avatar
You have a w56
Old Apr 21, 2009 | 08:09 PM
stagger_lee's Avatar
If he was carbed though it would be a G52 or G54 tranny through 1987.
Old Apr 21, 2009 | 08:14 PM
scuba's Avatar
This is a normal info plate thats normally on the drivers side door panel...
You can see in this picture the very bottom right code says "A340F"
If you have a w56 it will say w56 right there..
4banginRunner's Avatar
what motor?
Old Apr 21, 2009 | 08:17 PM
Or you can open your hood and see if there is a carb on there.
http://www.4x4wire.com/toyota/faq/parts/
Old Apr 21, 2009 | 08:31 PM
justen24's Avatar
well i thank for the help but i dont think it works for me its titled as a 85 cab says it is a 84 with efi in it and under the hood is a 22r motor it got a five speed tranny 4 wheel drive so i dont know
Old Apr 21, 2009 | 08:44 PM
can you get a pic of the top of the tranny?
Probably a G52
Old Apr 21, 2009 | 09:08 PM
justen24's Avatar
well i have two different trannys im trying to find out what they are i know off hand the one in the truck has a a six bolt cover around the shifter and the other one has a four bolt cover so i dont know if that helps or not
Old Apr 21, 2009 | 09:26 PM
Doesn't Marlin have a bunch of tranny pics on their site as well? g52 has 4 bolts around shifter if I recall correctly.
Here you go bruddah, you tell us what you have!
http://www.marlincrawler.com/transmi...built-complete
Old Apr 21, 2009 | 09:30 PM
Justinvd's Avatar
Typical tranny, can tell what they are? guy or girl
Old Apr 21, 2009 | 10:15 PM
justen24's Avatar
thanks stagger that was a big help know i know what kind of shifters im looking for
Old Apr 21, 2009 | 10:34 PM
DeathCougar's Avatar
Not in 84-88 he doesn't. The info plate is under the hood, attached to the firewall.
Same basical concept though, it will have a section labeled
C/TR
A/TM
C=Exterior Color
TR=Trim Code
A=Axle code
TM=Transmission
Old Apr 22, 2009 | 06:16 AM
I'm curious what you have now. Do tell.
Old Apr 22, 2009 | 06:56 AM
W56 has a 6 bolt shifter
G52 is 4 bolt
Old Apr 22, 2009 | 07:12 AM
Originally Posted by whokrz
You have a w56
Btw this is only true assuming he has EFI, and a STOCK trans.
If his truck is carbbed, he will have the G52 transmission.
Old Apr 22, 2009 | 07:52 AM
83's Avatar
83
Kind of off topic but what's the difference and why did they get different trannys? Is the W stronger? Is fuel injection that much more powerful that it needed it? Or efi w56 is just an overall upgrade nicer model truck so you get better stuff?
Old Apr 22, 2009 | 08:20 AM
Not really sure why Toyota decided to put two (3 actually, counting the turbo) transmissions in the trucks. Woluld have made sense to stick with all being the R-series, or all being the W-series I would think. But perhaps the W series is considered stronger, due to the EFI system producing more power?
I'll just hop in my Delorean, get her up to 88 mph, and go back in time to ask the execs why
Old Apr 22, 2009 | 10:08 AM
83's Avatar
83
Perfect! Let me know what you find out!
Old Apr 22, 2009 | 06:29 PM
justen24's Avatar
its a w56a in the truck and a l45 on the floor
