Sponsored by: CARiD
what do you think: 4Runner lift recommendations
Old Apr 17, 2010 | 08:46 PM
Magnusian's Avatar
From: Downtown Heckronto, Ontario, Soviet Canuckistan
Combination of exhaustion and alcohol; read words that weren't there, but I'm hoping you won't understand because you're underage and don't drink and go to bed at proper times.
Old Apr 17, 2010 | 08:50 PM
rebelrunner's Avatar
k gotcha.
Old Apr 17, 2010 | 09:09 PM
yotaman85's Avatar
no lift....... maybe a 2" body lift, but I would suggest 1" and only if you plan on lifting your drivetrain. just fit the biggest tires you can on the truck and get gears, lockers and sway bar disconnects. you will be able to do anything you want.
Old Apr 17, 2010 | 09:11 PM
Teuf's Avatar
Nix on the bodylift
Old Apr 17, 2010 | 09:17 PM
  #25
GranVille-4crawler's Avatar
Hahahahaha. Yeah +1 on yotamans post. I have 32x11.50s and no rub but I also have a solidfront axle. All I care about is downward travel
Old Apr 21, 2010 | 03:56 PM
  #26
bump
Old Apr 22, 2010 | 03:42 AM
  #27
WILLTHISIFSGOHIGHER's Avatar
Hey man I have a 92 Runner with 4" susp and 2" body I run 35" PRO COMP mudders and can rub on the pinch weld if I hit it really hard in just the wrong spot. I have 4:56 gears and think it could use a little more gear but overall it is awsome. I am gonna put a 1 1/2" ball joint lift too in about a month and a half, just so I can run some 35x14.50x15 Boggers with no rubbing. For now this is my daily driver, but once I get the boggers it goes in the garage and only out for fun in the mud.
Old Apr 22, 2010 | 03:36 PM
  #28
so you think it would be a good setup for me?
will 14.5'' wide boggers fit? seems like they will rub like crazy.
Old Apr 22, 2010 | 05:55 PM
  #29
My thinking is that I will hammer my pinch welds add the 1 1/2" ball joint lift and maybee 1/2 to 1" of torsion bar tweak and that gives me about 2 to 2 1/2" of lift and im only barely rubbing now so I think it might be same as now like if I turn all the way and then hit somethin hard then maybee some rubbing. But you know if thats the case I was thinking about some fiberglass fenders, they are pretty cheap. So do I think its a good set up for you I dont know but I know that with a 4" susp and a 1 1/2" ball joint lift you could run some meaty 33's or some skinny 35's and go just about anywhere. I shouldnt care so much about boggers maybee Ill check out some PittBull Rockers or somthin, the boggers have those lugs that stick out so far it just makes them so wide.
Old Apr 22, 2010 | 08:52 PM
  #30
thanks for the advice.
does anybody think i should should go a different route? im open to any suggestions.
Old Apr 22, 2010 | 08:57 PM
  #31
peow130's Avatar
Mud tears up your vehicle.
Expect to be changing out balljoints, tierod ends, and idler arm bushings every month.
Old Apr 22, 2010 | 08:59 PM
  #32
yeah i know but its fun.
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
skoti89
Jul 6, 2015 07:45 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
