Video of my stock 93' 4x4 not making it, all kinds of questions
like everyone else said locker is best bet there a little spendy if you dont really have the money at the time you can always put a spool in the rear or weld the gears its not a bad upgrade for the price but it will wear your tires quickly also tires will help of coarse
welcome to YT! sweet truck, looks just like mine.
i'd just wheel the crap outta your truck stock to learn its capabilities and as funds permit, upgrade it. you'd probably learn a lot more wheeling with open diffs and playing it smart than being overconfident with upgrades and getting yourself into a sticky situation. it wouldn't be a bad idea to go back to that spot and try some different things out to see what works or not.
new tires won't make that much of a difference if your diffs are still unlocked. wheel it more and determine if a lunchbox locker is right for you vs saving up for selectable. if i were to do it again i'd have saved up for selectable - it's not the tire wear, it's the slight binding of the drivetrain on an xcab truck that i don't like.
first thing i would put $ into would be make sure the truck runs very well and to buy some recovery equipment - basic tools, a matching spare, a tow strap, some tow points (rear especially since there's none), and a hi-lift jack. oh yeah and cb radio so you can talk to your buddy in another rig because you should never go out solo.
i chose to upgrade my truck in this order: wheeled it stock w/31" tires, 2" lift and swaybar removal for more flex and tire contact w/ground, 4.88 gearing rear locker and high clearance rear bumper, NOW i'm finally getting to putting some MT tires on her - to be followed with more armor because now i can go more places and get into sticky situations.
Good luck!
Good luck!
While a locker makes life easier, I'd strongly suggest you buy a set of all-terrains in whatever size and tread pattern you like. Then, learn how to pick a line. If your truck is anything like my 86, it doesn't flex worth a darn. You'll need to learn how to keep the tires on the ground. Airing down is your friend.
I drove up this with open diffs, 30x9.50-15 all-terrain tires and tires aired down. It took some work, but I managed it without crazy amounts of throttle and picking the right line.
By rjhodges12 at 2011-03-21
Good luck!
Good luck!
GreenLion
Jun 7, 2021 10:49 AM
voiddweller
19
May 2, 2016 09:10 PM
