Sponsored by: CARiD
Vibration
Old Feb 28, 2007 | 12:39 PM
GORDON718's Avatar
Vibration
While Driving My 99 Taco Prerunner It Vibrates A Little But When I Get To About 65mph It Vibrates Heavily. Passenger Seat Shakes And The Steering Wheel Chimies. Any Ideas?
Old Feb 28, 2007 | 12:43 PM
UKMyers's Avatar
U joint or carrier bearing probably. Rotated or balanced your tires on schedule??
Old Feb 28, 2007 | 02:48 PM
Nic's Avatar
Nic
I (and many others) have had this exact same problem. Usually it can be attributed to bad or improperly balanced tires. The fix can be as simple as finding someone that knows how to balance the tires properly. The Toyota wheels are reputed to be lug centric and not hub centric, and reguire a special adapter to really balance them correctly. The dealers are supposed to be able to, but I wouldn't hold my breathe.
I had mine balanced several times and explored everything I could think of including the driveshaft, hangar bearing, and u-joint -only to realize it was tires. I had to replace mine though.
There are several threads on this. Do a search and you will find a bunch of info.
Old Feb 28, 2007 | 03:30 PM
CyMoN's Avatar
since I bought my truck about 8 months ago Im had a vibration and figured it was the U joints well last week took in my truck to have a few nails removed from all the tires and had them rebalanced as well
and now it does not shake at all payed 50$ for them to rotate and re balance and plug all the tires.
it was well worth it.
hiluxinargentina
Sep 30, 2015 05:51 PM
JPV
Sep 28, 2015 03:15 PM
Odin
Sep 26, 2015 06:56 PM
4Xtruck
16
Sep 24, 2015 09:38 AM
tinigunner11
Aug 14, 2015 01:19 PM
