Sponsored by: CARiD
u-bolt flip plates
Old Jul 28, 2011 | 09:20 PM
brysawn's Avatar
u-bolt flip plates
I'm going to be flipping my u-bolts and making the plate myself. I'm going to be using the trail-gear design. I'll use 1/2" steel plating and bend it up at the end. But will I need to relocate my shocks on a 94 4x4 pickup?
Old Jul 28, 2011 | 10:07 PM
scuba's Avatar
Yes.
Old Jul 28, 2011 | 10:23 PM
brysawn's Avatar
Is there a way to use round u-bolts without a flip kit and/or relocating my shocks?
Old Jul 29, 2011 | 12:12 AM
scuba's Avatar
Well, what benefit would you be getting by using round u bolts if that big u bolt plate/ lower shock mount is still under the axle..?
Old Jul 29, 2011 | 04:22 AM
brysawn's Avatar
I got them for free, I was hoping I could make them work. It looks like I'll have to relocate my shocks, get a flip kit or some square u-bolts
Old Jul 29, 2011 | 04:23 AM
waskillywabbit's Avatar
1/2" will be fun to break. Too thick and unnecessary. Try 1/4
:wabbit2:
Old Jul 29, 2011 | 06:22 AM
tlrskunk's Avatar
:wabbit2:
I think this is one of the first times i have ever seen someone on here actually so that is too thick and unnecessary. Everyone acts like it all needs to be way over built. Thanks for correcting him Wab.
Old Jul 29, 2011 | 06:55 AM
brysawn's Avatar
I planned on using 1/2" because thats what I usually have at the house. But I'll get some 1/4" instead.
Also, I'm wondering where I can get the mounts for the shocks, to reweld them to my axle?
Old Jul 29, 2011 | 07:09 AM
4Crawler's Avatar
I like the heavier spring plates, they are so much nicer when it comes to torquing down the u-bolts. My old axle had flat 1/2" plates and I now run 3/8" plates with bent up ends. I find on the thicker plates, the u-bolts tighten up in a turn or so while with the thinner plates like I first got from All-Pro, you had to keep cranking and cranking on the torque wrench before they would get tight. The thinner metal just would deform around the spring pack.
Lots of places may the shock tabs, pick the style you want or BudBuilt has some bolt-on versions. I originally ran a shock mount that slipped in under the spring pack, that worked well:
- http://www.4crawler.com/4x4/4R_suspe...shtml#R-Shocks
kawazx636
Oct 6, 2021 03:03 PM
scott90
Oct 4, 2015 09:21 AM
kawazx636
Sep 29, 2015 08:22 AM
bhaithc
Sep 17, 2015 07:53 PM
AlexJet
Sep 14, 2015 09:00 AM
