Sponsored by: CARiD
Truck wont run
Old Oct 11, 2013 | 10:57 PM
evan711's Avatar
Truck wont run
I have an 87 pickup 22re I rebuilt and it wont run has new fuel pump and filter also is getting fuel to the rail and has spark and will run of starting fluid when sprayed in the intake. I looked at the computer and it has a corroded electrodes and smells kinda burnt I need to check the ecu harness, but what are your guys thoughts what it could be.
Old Oct 12, 2013 | 01:03 AM
wyoming9's Avatar
Red face
From what you said it sounds like your injectors are not getting the signal to fire.
Could just be a poor or corroded connection poor ground connection
If it ran before and you didn`t hook things up wrong and fry the ECU or have it sitting in a bucket of water for a few days.
I would look at connections
Old Oct 12, 2013 | 01:39 AM
evan711's Avatar
thanks im gonna do that
Old Oct 26, 2013 | 04:41 PM
Josh_Br's Avatar
Just a thought - I think if the throttle position sensor is not adjusted properly, it might give you similar trouble. I'm not certain, but it might be something to check out next if what they said above doesn't work.
Old Oct 27, 2013 | 01:21 PM
evan711's Avatar
I tried a bunch of stuff and found out my ecu harness is junk and I just was so tired of the efi I went and bought a 22r intake and a weber 32/36
Old Oct 27, 2013 | 02:18 PM
Josh_Br's Avatar
Sounds good!
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
puffin04
Jul 10, 2015 09:17 PM
Badger62811
Jun 26, 2015 09:26 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
ibayne
Jun 26, 2015 06:30 AM
