Sponsored by: CARiD
tire and rim size ???
Old May 23, 2011 | 02:22 PM
veeyota's Avatar
i have some rims, it says 15x7. if i wanna run 31 inch tires on it, whats the width that i can go with?? cause i see tires that says 31x10.50r15. will those fit on mine?
Old May 23, 2011 | 03:33 PM
warpigg's Avatar
yes they will fit
Old May 23, 2011 | 04:22 PM
veeyota's Avatar
what's the 10.50 for ??? i wanna know cause how could a 10.50 wide tires fit on an 7 inch wide rim?? or is that what it means?
Old May 23, 2011 | 04:34 PM
xxxtreme22r's Avatar
10.5 is the overall tire width in inches including the sidewall bulge which might differ from the actual track/tread width. Yes they will fit perfectly.
P.S. You DO NOT want to put a 10.50 tire on a 10 inch wide wheel.
Old May 23, 2011 | 04:50 PM
Resto-noob's Avatar
He's dead on. I had a set of 31" Dunlops on 10 inch rims that I picked up in a trade (back when I was young and dumb). Thankfully the 22RE/Auto combo couldn't let me go fast enough to get into trouble. I did manage to crack a rim on a dirt road and it wasn't pretty. A little sidewall bulge is good protection. (gotta be a joke in there)
Old May 23, 2011 | 04:52 PM
warpigg's Avatar
that would be scary
Old May 24, 2011 | 05:30 PM
veeyota's Avatar
thanks for the info
Old May 24, 2011 | 05:44 PM
racehoss's Avatar
What about a 33x10.5 on a stock 15x6 rim?
Old May 24, 2011 | 06:05 PM
rattlewagon's Avatar
Yes it will fit.
Old May 25, 2011 | 08:26 PM
veeyota's Avatar
will lug pattern 6x114.4 fit on an 91 yota truck?
Old Jul 18, 2011 | 07:35 AM
irab88's Avatar
bump to avoid a new thread:
i'm looking at putting a 31x10.5r15 on a 15x6 taco steelie, and was wondering if there were any adverse effects. this will be my dd at 100 miles a day. and this is also a pic request, if anyone has this set-up
Old Jul 18, 2011 | 07:45 AM
ian your fine, but you might have to adjust the tire pressure accordingly. When I wanted to run 13.50 tires on an 8" wheel, which is fine BTW, only adverse affect is it might create a little more center tread wear as the tire will want to curve the tread a little. This can be remedied by running a slightly lower tire pressure. In addition to this your steering "might" feel a little squishy as the tire will want to wander a bit more on left to right movement. But it's a truck and you shouldn't be making any fast tight turns with it anyway so........
but a 10.50 tire on a 6" wheel is pretty much the same as running a 12.50 tire on an 8" wheel which is done all the time, including by myself.
Old Jul 18, 2011 | 08:40 AM
dropzone's Avatar
Fossilized
seems like a 10.5 on a 6" rim is gonna look kind of balloonish...thought taco steel rims were 7" wide....been awhile since I had my '97....
Old Jul 18, 2011 | 08:44 AM
irab88's Avatar
i measured using this chart. 6" for the wheels i currently have, and 6" for the taco's
Old Jul 18, 2011 | 08:47 AM
my 12.50's on an 8" doesn't look too balloony.
And earlier in my build thread, I had 31 x 10.50's on a 7" wheel as well. Now my spare was a 31 11.50 on a 7" which looked a little odd.
Old Jul 18, 2011 | 09:19 AM
irab88's Avatar
found one pic:
(31x10.5r15 on 15x6)
Old Jul 18, 2011 | 12:26 PM
irab88's Avatar
and another. thank you, h.b.yoter!
Old Apr 20, 2015 | 03:15 PM
sean43's Avatar
wheel size
I currently have 33"x10.50x15 BfGoodrich tires on my '85 4runner. Im buying a new set of tires and getting a spare. the wheels I have are solid black, 6 lug, and have 8 circular wholes in the pattern. They are plain, no deadlock. Im having trouble finding a match, was wondering if I could get some suggestions. Also, for this size tire, do I order a 15"x7" when I find the right one.
Old Apr 21, 2015 | 08:42 AM
SacRunner's Avatar
They could be these: http://www.cragarwheel.com/products1...s397BlackSoft8
But they make those in all sorts of sizes (diameters and widths); you're going to have to do something to measure the ones you have and order a matching size. 15x7 and 15x8 will both work with a 33x10.5 (I have had 15x8s with a set of 31x10.5, 33x10.5, and now 33x12.5).
Old Apr 22, 2015 | 04:02 AM
sean43's Avatar
Thanks, I'll do measuring and then research it and find the right one
