Sponsored by: CARiD
timing without removing chain cover
Old Apr 24, 2011 | 10:58 AM
scottyboy's Avatar
Question! 22r toyota 4runner efi. cam bolt backed out and timing gear came off. motor has jumped time and probly bent a few valves. is it possible to retime motor after my new head is instaled without removing timing chain cover. motor is in truck.
Old Apr 24, 2011 | 11:52 AM
snobdds's Avatar
No.
I don't see any way you could run it around the bottom sprocket and be 100% sure it's on right.
Old Apr 24, 2011 | 12:09 PM
scottyboy's Avatar
The chain is still in tacked. My problem is getting timing marks on bottom gear alined so I can instal top timing gear.
Old Apr 24, 2011 | 06:49 PM
annoyingrob's Avatar
If you're re-using the old chain then of course you can keep the cover on.
The big question is WHY do you want to? It takes like 5 minutes to remove the timing cover. Might as well replace the whole timing assembly while you have it apart.
Old Apr 24, 2011 | 07:17 PM
1988mudder's Avatar
I would agree with annoyingrob on this one...instead of messing with it for 3 hours I'd just take the cover off and be able to see everything! Just my 2 cents
Jun 1, 2021 01:51 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
