Sponsored by: CARiD
Thermostat?
Old Sep 11, 2007 | 10:24 AM
my4runner's Avatar
Thermostat?
Is there any difference in performance or possible harm to the motor if the thermostat is not installed? Thanks
Old Sep 11, 2007 | 10:25 AM
OSU4Runner's Avatar
Your fan won't turn on unless you hardwire it, and your heat won't work right either.
Old Sep 11, 2007 | 11:31 AM
my4runner's Avatar
I have a 1988 4runner 22re motor, it doesnt have an electric fan, it has the clutch fan, which works fine.. thanks for the reply
Old Sep 11, 2007 | 11:48 AM
aaronk's Avatar
Can I ask why you would want to do so? I new thermostat from Toyota only runs about $15.
Old Sep 11, 2007 | 12:07 PM
OSU4Runner's Avatar
haha I'm a dumb a$$...sorry i was looking at electric fans when I wrote that reply. Ya but the only thing it would probably affect would be your heat, your engine wouldn't heat up as quick, due to the coolant always flowing through the radiator. Might affect your engine performance as well, but I'm not sure on that one.
Old Sep 11, 2007 | 12:14 PM
4Crawler's Avatar
On an EFI engine, you may not reach proper operating temperature. If so, the ECU will keep the fuel mixture richer in order to warm up the engine. Could result in less fuel economy.
Old Sep 11, 2007 | 12:28 PM
my4runner's Avatar
Thank you all for the replies, I had posted questions on how to set the throttle position sensor, well, when I took the thermostat hose and housing off to adjust the sensor, I noticed the thermostat was not there..I had a new cylinder head replaced, they didnt put the thermostat back..so, what is recommended, I know there are different temp T-Stats, again, thanks for the help.
kawazx636
Oct 6, 2021 03:03 PM
wberry85
May 17, 2016 05:45 PM
White Stripe
Oct 6, 2015 10:47 AM
rmill05
Sep 27, 2015 01:43 PM
LotOMiles
Sep 14, 2015 11:45 PM
