Sponsored by: CARiD
Tacoma: Better traction
Old Aug 23, 2007 | 09:12 AM
TacoTime's Avatar
I have a non TRD, can I get the third member from a TRD and swap it in my rear axle?
If not what do you guys reccomend, I don't want a lunch box locker. I think a e-lock is the way to go, so is detroit the way to go.
thanks guys I'm coming from full size/dana axle side of the world and don't know jack about toyo axles. good ring gear size!
Old Aug 23, 2007 | 09:18 AM
RunnerUp's Avatar
just cause its a TRD doesnt mean it has the locker, make sure it does before you pull it, and it would prob be easier to just change the whole axle, that way you dont have to modify your pumpkin at all
Old Aug 23, 2007 | 09:19 AM
TacoTime's Avatar
I like to modify, found something
http://www.sonoransteel.com/phong/re...ic_locker.html
and another, https://www.yotatech.com/forums/f37/...-gears-117860/
off to pirate 4x4.........................
Old Aug 23, 2007 | 09:20 AM
RunnerUp's Avatar
and if you just wanted to buy a new 3rd member set up you can get a new one with 4.10 gears for 950 from marlin crawler
http://www.marlincrawler.com/htm/diff/pickup_diff.htm
Old Aug 23, 2007 | 09:25 AM
RunnerUp's Avatar
alright.. that does it
thread hijack on
does anyone know if 2002 4runners that didnt even have the option of a locker have the RR diff lock light somewhere?
thread hijack off
Old Aug 23, 2007 | 09:31 AM
Kaleb's Avatar
I thought the Tacoma axles use 8.4" ring gears, and the E-locker uses an 8" ring gear?
Old Aug 23, 2007 | 09:37 AM
90RunnerRed's Avatar
That was my recollection as well. So I don't believe you can swap just the third.
I thought all TRD Tacomas did come with the locker.
Old Aug 23, 2007 | 10:17 AM
AxleIke's Avatar
Non TRD Locker equipped axles have an 8.4"
TRD Locker equipped have an 8"
Just get the whole housing, and you'll be fine.
Old Aug 23, 2007 | 11:24 AM
tc's Avatar
tc
As in the entire drum to drum assembly.
Thirds are not interchangeable between TRD and nonTRD Tacomas.
You could go with a Detroit locker or an ARB in your existing housing/thirdmember.
Ox, ECTED, Electrac, etc are not available for Toyota axles
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
justdifferentials
Just Differentials
14
Sep 24, 2017 08:32 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
sonorn67
Sep 19, 2015 05:39 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
