Sponsored by: CARiD
Sway Bar bushing replacement
Old May 30, 2006 | 11:33 AM
TheDarkKnight's Avatar
I've been driving around with a slight squeek coming from othe front end.
Last week, I was crawilng around underneath, and noticed that the bushings on the front sway bar are... dead.
So, I have been looking around to see if there are any threads that will give me a PN for new bushings.
Right now, I am considering either Energy suspension 25mm universal bushings or the kit from Wheelers.
http://www.wheelersoffroad.com/4runswaykit.htm
1. What is your opinion/experience on these?
2. I have never replaced sway bar bushings. How hard it is, and how much time should I expect? (I assume that I cant just loosen the original bolts, pop in the new bushings and I am done - rather I will have to take a bunch of "stuff" off?)
Thanks for the help.
tdk
Old May 30, 2006 | 03:52 PM
FORANA's Avatar
I bought the energy suspension bushing and they are good. They are easy to install, the hardest part was getting the steering stabalizers off but even that wasn't too bad.
Took an hour or 2, me being useless with tools.
Old May 30, 2006 | 04:45 PM
Bob_98SR5's Avatar
dark,
there are pages of threads on the energy suspension bushings. please search and read.
moved to newbie section
bob
Old May 31, 2006 | 06:58 AM
Gerdo's Avatar
I just installed a poly swaybar set from wheelers. https://www.yotatech.com/forums/f2/poly-swaybar-bushings-85293/ They went in easy. Mine were shot also. The kit comes with poly bumpstops also, I did not use them I kept the original rubber ones.
Old May 31, 2006 | 02:22 PM
jtmaxx7's Avatar
Super easy. I as well just replaced the sway bar bushing and not the bumpstops.
My OEM bushings didn't see warn however the energysuspension ones made a noticable differance.
Old Jun 23, 2006 | 11:00 AM
newhorizons's Avatar
on my stock 86 runner I just replaced both of mine(noticed one was completly BROKE while changing the calipers/brakes). I just cut them off,to rusted to mess with otherwise.
Old Jun 23, 2006 | 11:17 AM
lofreqjeff's Avatar
Why not just take the sway bar off....
I recently took the bar off my 89 4Runner and there is almost no difference with the on-road performance, but it makes a alot of difference.
Just my 2 cents
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
andrewtexas123
Jul 14, 2015 04:29 AM
ptb12
Jul 5, 2015 01:49 PM
Vargntucson
Jul 4, 2015 12:15 PM
