Sponsored by: CARiD
Stumbling Idle, new engine, please help.
Old May 18, 2009 | 08:42 AM
tango71's Avatar
Ok I cant figure this out for the life of me.
1995 4runner 22re brand new rebuild. 175psi compression across the board, timing set to factory 8* BTDC.
Engine ran fine for the first two days and then developed a weird idle issue. it looks like cyl 2 is not firing, but it is.
When I pull the plug wire when the engine is cold there is a big difference in idle speed. once the engine is warmed up and I pull the plug wire nothing changes. If I pull the plug wires on any other cylinders the engine idle stumbles even more.
In higher RPM the cyl is firing. I pulled the spark plug and its a nice golden tan color like it is supposed to be. So it is getting fuel.
Another thing I noticed by accident (I was replacing injectors for new ones thinking that may be my issue and forgot to put the gasket back in between the EGR and Intake) is that when I had a major vacuum leak the motor ran funny. But when I pulled cyl number 2 plug wire it did make a difference in idle and stumbled right down.
Could it be my EGR putting out too much in to the intake and suffocating cyl 2 ? You can feel the miss by putting your hand to the tail pipe. Its not a strady exhaust stream.
I did fail NOx the other day when doing the emissions test, However I think that may be my fault because I accidentally set the ignition timing to 16* It passed on idle just not in high RPM. Passed everything else though.
So if anyone knows what my issue may be, let me know. I'd love to clean up the idle on this car.
I checked the TPS, its fine, Timing is fine and there are no vac leaks, I sprayed the engine down with carb cleaner and no difference in RPM.
Old Jun 5, 2009 | 04:57 PM
ryan19914runner's Avatar
do you have lack of power aswell
Old Jun 6, 2009 | 03:40 AM
tango71's Avatar
Yes I do. Seems pretty gutless.
Old Jun 11, 2009 | 04:46 PM
i have the same problem 1991 4runner auto 4 cyl. sometimes it runs great i have checked plugs wires cap rotor tps coil distibuter fuel filtermass air flow o2 sensor it s weird every time i change something it runs great till the next morning then back to normal. i am getting very frustrated with it i don t know what else to try except the ecu any ideas let me know is there any thing else you have tried
Charecter1
Nov 6, 2023 10:08 AM
Yota.Jay
Jul 23, 2015 08:08 PM
redneck17
Jul 17, 2015 07:44 PM
bryan34w
Jul 6, 2015 05:53 PM
Jnkml
Jul 6, 2015 01:20 PM
