Sponsored by: CARiD
stumbles and misses then starts to over heat
Old Jun 30, 2012 | 07:07 AM
lacrosseking1991@yah's Avatar
My 85 short body 22r is miss firing when accelerating as it starts to miss fire she
will slowly start to over heat... last week i had the same problem... i drained the
gas and changed the fuel filters... then it ran fine, wasnt hesitating drove it like
i stole it and wheeled it all weekend and drove home a total of 200 miles... now
im having the same problem again. so i performed the same procedures as
before drained gas and changed filters.... shes still very hesitant and
overheating again im scared and sad... she is not only my weekend worrier but
she is also my daily driver to and from work...
Old Jun 30, 2012 | 07:11 AM
idk im lil lost
is it the fuel pump... where can i get a fuel pump that draws more fuel and bolts it to the stock location... im no mechanic but so far ive performed all the maintenance on my baby
Old Jun 30, 2012 | 12:23 PM
myyota's Avatar
Any parts store should have a fuel pump for your truck.
Be sure to check all of your vacuum lines, and replace any bad lines that you find.
Old Jun 30, 2012 | 01:21 PM
thanks man but i checked my fuel pump and its drawing fuel and sending it back to my tank as well it seems to starve for fuel tho, wish i could find an electric fuel sending unit that i could mount to my frame to Help the fuel get to my mech fuel pump, i even tried mounting fuel filters vertical
Old Jun 30, 2012 | 01:57 PM
myyota's Avatar
Have you ever replaced your gas cap ?. The gas cap has to be a vented style, otherwise a cacuum will build up in the gas tank, and that could a lean condition or fuel starving.
Another thing to check is the charcoal canister on the passenger side of the engine compartment, it is also part of the vent system for the gas tank. There is a hose that comes off the bottom, make sure its not plugged with mud or dirt.
Old Jul 1, 2012 | 06:15 AM
thanks man im sure going to check charcoal canister next been chasing this problem for almost a week now and getting zero results
bigjstang
Jun 2, 2025 03:56 PM
icentropy
Sep 16, 2020 02:47 PM
cyclist231
Jul 7, 2015 12:56 PM
ptb12
Jul 5, 2015 01:49 PM
