Stock tire size on a 91 4runner
stock tire was a 225. 31" was an option but the door tag will still say 225. You need to look at the gear ratio to determin if it was set up for the 225 or the 31". Or call you r local dealer. There is a good atricle here on the tires & rims & gear rations. Do a search
gear ratio will be easy to tell... do you have a factory swing type spare tire holder if you do i think think the gear ratio is 4:56s for the 5 speed or 4:88s for the auto if you dont have the swing type then you have 4:10s
I found the door jam sticker and it said 225's. the code according to the search I did says I have the 4:56 gears I forgot to check the spare tire. I have 32 x 10.5 on it and at 60 mile and hour it is rapping 2600 which does not seem to be to bad. How much taller are 31 then 225's?
Jun 1, 2021 01:51 PM
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
Aug 30, 2016 01:03 PM
