Sponsored by: CARiD
steering shaft / wheel
Old Nov 16, 2006 | 03:52 PM
otis50's Avatar
I've just finished converting my 94 steering from manual to power- was a bit more involved than anticipated. Works great, though. I must have inserted the steering shaft a little off, because when I'm going down the road, the 'bottom' of the weel doesn't point to me- it points out the driver window.
Not a big problem. The turn signals don't click 'off' as usual, though, when you turn a corner- one clicks off too soon, the other not at all. I understand why.
If I take the steering wheel off, will I be able to 'realign' both the wheel and turn signals so all work properly? Or to I need to take the shaft out (a whole lot of work) and attack it from that angle?
Would appreciate comments!
Old Nov 16, 2006 | 04:55 PM
HAVOC's Avatar
"was a bit more involved than anticipated"
isn't that always the way
If you "move" the wheel it will fix your straight ahead position of the wheel, but not fix the turn signal. You will have to unbolt it (shaft) from the box and "center" the column. You still need to take the wheel off to see where the turn signal cancel is at.
Almost forgot, you will still need an alignment, because your toe will still be off enough to possibly cause premature tire wear.
Old Nov 17, 2006 | 08:10 AM
otis50's Avatar
That's what I was afraid of! Thanks for your help!
Old Nov 20, 2006 | 11:26 AM
4Crawler's Avatar
Just re-center the turn signal cancel cam with the wheel off, or you can pull the shaft out at the firewall and rotate the whole thing there.
A2theK
Jan 10, 2016 10:18 AM
Up&Down
Aug 11, 2015 10:04 AM
terminator
Jul 27, 2015 07:13 PM
yoterr
Jul 24, 2015 04:29 AM
