steering arm skyjacker pitman arm ball top bottom question
Hi i need help! I am installing the 7 in Skyjacker. I have a hi steer already installed in my 1985 4runner. i want to know if i even need to worry about the step that says turning the ball around in the steering arm? Can someone please answer this for me thank you. Thinking about installing myself but dont want to but welding equipment. Thanks!!!
do you know if you have to adjust any of the components of the hi-steer set up to install the 7 in skyjaker lift? It seems to me that i just need to swap out the springs pretty much. Is this correct or would i need some other parts?
Is your truck currently lifted as of right now?
Because you seem uncertain about it.
If your truck has hi-steer, which means it has aftermarket steering arms on the knuckles, then you should just be able to install the springs.
yes it has 4 in lift but sagging on the driver. The reason i am asking is because i just want to buy springs only not the entire kit. thanks you guy for helping me! it has hi steer! i took pictures but they are too big of file to upload sorry.
Front springs are same on Skyjacker lift kit? right and left are same spring?
Why is procomp lifts for front two different springs but skyjacker is the same spring left and right? I know Trailgear sales a plate to raise the spring on driver side but i cant find this with skyjacker kit. Do i need this or does skyjacker have "Magic" springs? ONCE THEY ARE ON THEY LEVEL OUT?
PLEASE HELP
PLEASE HELP
Sep 4, 2015 09:27 AM
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
Jul 9, 2015 02:34 PM
