Sponsored by: CARiD
squeak over bumps
Old Feb 7, 2007 | 09:53 AM
taikowaza's Avatar
squeak over bumps
another 2nd gen squeak question, I have an OME suspension coupled with a downey HD coil setup.
I am getting squeaks when I go over bumps. I cannot localize it (which side it's coming from), when I get out and push down on the vehicle I cannot reproduce this, only when I am driving. I have lubricated all chassis points but now am interested in lubricating coils/shocks, is this even done?
where are the lubrication points for the suspension if applicable
sdori ball joint spacers
sonoran steel IFS truss (awesome)
OME front and rear
Downey HD coils
taiko
Old Feb 7, 2007 | 09:55 AM
Bassinfool's Avatar
forgive my ignorance, I don't know much about your suspension parts, but here is my $.02.
I had a squeek similar from the rear of the truck, ended up being the rubber bushings in my leaf springs. Try lifting UP on the back and see if it does it. I replace them with Polyeurethane bushings and problem solved. (My old '92 pickup).
Old Feb 7, 2007 | 03:21 PM
dh515's Avatar
Same deal here. Had very annoying rattle when hitting bumps and thought it was the tailgate. Ended up being the rear leaf spring bushings. Replaced with polyurethane and no more noise.
Old Feb 7, 2007 | 03:34 PM
slosurfer's Avatar
check the bushings on your swaybar where it attaches to the frame.
Old Feb 7, 2007 | 03:51 PM
MudHippy's Avatar
Some types of poly bushings come greasable. This is to reduce squeaks. My poly bushings in the rear actualy make more noise than stock. Was a progr. thing, not when new.
Old Feb 8, 2007 | 07:11 PM
colsoncj's Avatar
Another thing to consider, if it squeaks when you hit a bump, and have the wheel turned all the way to lock, its the bump stops for the steering.
Obmi
Oct 4, 2015 11:30 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
kawazx636
Sep 29, 2015 08:22 AM
83
Sep 27, 2015 04:13 PM
altydog
Sep 20, 2015 07:37 PM
