Sponsored by: CARiD
Spark plugs
Old Jan 21, 2007 | 06:54 AM
Choopster's Avatar
Spark plugs
Please recommend which spark plugs would be best for a '98 4runner w/ supercharger and cold air induction. Thanks...
Old Jan 21, 2007 | 07:01 AM
BajaRunner's Avatar
NGK or Denso are the recommended plugs for the engine. I'd assume to stick with those. They need to be dual electrode.
Old Jan 21, 2007 | 07:56 AM
MTL_4runner's Avatar
Either the Denso 5062 dual electrode plugs or the Iridium IK20 or IK22 long life plugs.
Old Jan 21, 2007 | 08:16 AM
TRDatVT's Avatar
What is the reason to run dual electrode? Our ignitions do not produce/use enough power for that to matter. I use standard v-power NGK's with a 7 heat range and gap them down to 0.037. I change them every other oil change at that price (1.50 per plug) If you want, i can get you the part number for them since some people run into trouble getting the cooler heat range.
Old Jan 21, 2007 | 08:19 AM
wjwerdna's Avatar
www.sparkplugs.com, and choose the NGK or Denso plugs after typing in all your info, then when checking out put "dodgetalk" in the promo box for 10% off... I just ordered plugs and wires yesterday there
Old Jan 21, 2007 | 09:06 AM
Choopster's Avatar
Thanks very much, is their a specific NGK or Denso aprt # that is the best to use based on my trucks equipment?
Old Jan 21, 2007 | 09:14 AM
wjwerdna's Avatar
no, not on that site, they are all close to oem I believe...
edit: sorry, I saw cold air induction, but skipped over supercharger... I was just looking for plug recommendation and I know the topic covering superchargers and plugs has come up a few times before... don't remember where though.... spend some time searching, you should come across it
Old Jan 21, 2007 | 09:23 AM
Choopster's Avatar
Thanks WJWERDNA, I will start looking.
Old Jan 21, 2007 | 09:49 AM
ohio4runner4x4's Avatar
Running NGK 4302's in both of my 4R's....
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
raptor510
Aug 19, 2015 02:15 PM
accuracy
Aug 4, 2015 08:05 PM
defrag4
Jul 31, 2015 10:50 AM
