Sponsored by: CARiD
Simple LED wited to a switch --- Why won't it work?!
Old May 24, 2013 | 01:25 PM
cartercoulombe's Avatar
Hey guys,
I know there are a ton of threads that already talk about this mod, but I can't seem to find one that addresses my particular problem.
So I am wiring a few LEDs throughout my 92 Ext Cab Pickup, the first one up is an engine bay light.
I have installed an auxiliary fuse box under the hood, since I plan on installing multiple LEDs, I wanted to keep it as neat as possible and only have one wire tapped into the battery.
I also have an array of switches (3 prong, illuminated rocker switches) in the cab, this is where I plan to run all the LEDs to.
OK. So, I installed the LED under the hood. --- I can get the LED to work just fine without the switch, so I know that's not the problem. However I can't get the switch to function.
Here is how I have to wired, please help!
BATT POS --> AUX FUSE BOX
LED POS
--> SWITCH POS #1 (on/off)
SWITCH POS #2 (LEAD) --> 5A FUSE in AUX FUSE BOX
LED NEG --> BATT NEG
SWITCH NEG --> GROUND
I have also tried this configuration: (just switched the two positive wires going into the switch)
LED POS
--> SWITCH POS #2 (LEAD)
SWITCH POS #1 (on/off) --> 5A FUSE in AUX FUSE BOX
What am I doing wrong here?
Old May 24, 2013 | 01:43 PM
And here is a little diagram I drew up. Thanks again!
Old May 24, 2013 | 02:34 PM
93Xtra-Cab's Avatar
The wire from the fuse box should be going to the middle prong of the switch.
The only other thing I can think of is that the switch isn't rated for what you're using it for, which I highly doubt because LEDs draw such little current.
Here's a schematic I just found:
Old May 24, 2013 | 03:30 PM
slo6i's Avatar
You might have burned it out, unless it was rated for 12v. They burn out VERY quickly if they are not wired to the correct power source. Even if it is rated for 12V, it might be a good idea to do the math and put a resister inline to ensure its getting the correct constant voltage. Use:
Resistance = ( (Vs) Power Supply Voltage - (Vf) LED Voltage Drop ) / (I)LED Current to determine the amount of resister you need.
Ex. If your LED's Forward voltage (Vf) is 3.5, and voltage drop is 20mA (I), and Power Supply is 12 then:
Resistance needed = (12 - 3.5) / .20 = 42.5 Ohms
That will limit the power to what that certain LED needs.
Just something to think about.
Old May 24, 2013 | 04:11 PM
93xcab -
Thanks for that diagram, that is exactly how I have it wired. Yeah I wouldn't think anything is getting overloaded by a tiny LED. It must be something else.
Slo6i -
Thanks for the response, so you are saying that the switch might be burning out? It is designed for 12v, and I have 4 of them, all of which I have tried with the above configuration. Hopefully I didn't burn them all out? All that resistance math seems complicated, is there an easier way to do it without any special electrical tools? I don't have a voltmeter or anything like that.
Old May 24, 2013 | 04:32 PM
slo6i's Avatar
Originally Posted by cartercoulombe
93xcab -
Slo6i -
No. I was talking about the leds themselves. If it was designed for a 12 volt system, then there's no need to worry about the resisters as they will be built into your units. Are you sure the supply that you are using isn't a switched 12v meaning the key has to be on or the engine running? Do you have a link for the specific leds you bought?
Old May 24, 2013 | 04:47 PM
93Xtra-Cab's Avatar
The way he shows it in the diagram, it looks like the key doesn't have to be turned on for it to work since it's hooked straight to the battery, not any ignition line.
^This. A link would definitely help.
Old May 24, 2013 | 04:50 PM
SoCal4Running's Avatar
Are you sure you wired the LED correctly?
The longer of the LEDs legs is positive.
If wired backwards some will not turn on while others will be destroyed.
Old May 24, 2013 | 05:08 PM
RAD4Runner's Avatar
Originally Posted by 93Xtra-Cab
The wire from the fuse box should be going to the middle prong of the switch.Here's a schematic I just found:
Do you have an LED Array already made to wire directly like in 93Xtra-Cab's schematic? If you do, you just need to make sure you connect in right polarity
OR do you have component LED? In that case, you probably already blew it, unless you used a limiting resistor as slo6i mentioned above.
Old May 24, 2013 | 05:24 PM
93Xtra-Cab's Avatar
If it is one of those LED strips, make sure the wires are still connected. I got a couple off of eBay once and I had to re-solder one of the wires back on. Just a thought.
I still think the problem is in the switch. He says in the first post that it works fine unless it is hooked up to the switch.
Old May 24, 2013 | 06:32 PM
No it is not a strip, but more like a wafer type LED, here is the link: http://www.ecolightled.com/product/s...led_4w/g4_leds
I bought a few of these for my dome light, they are SO bright its rediculous. The leftovers are going in the engine bay.
And guys, the LED is fine, it works perfectly without the switch involved.
Old May 24, 2013 | 06:42 PM
And here is the link for the switch if it helps http://www.pepboys.com/product/detai...36/?quantity=1
Old May 24, 2013 | 07:26 PM
slo6i's Avatar
Yeah, those little wafer boards should already have the resistors in them if they are specifying a 12v power source.
My only guess is that the wiring to the switch is wrong.
It looks as though that switch is setup differently than the one xcab posted. looks like the constant 12v goes on one of the outside terminals.
You might also try wiring it inline with the supply wire or the ground wire to open the circuit.
Old May 24, 2013 | 10:12 PM
RAD4Runner's Avatar
Agree, module already has resistors.
"Supply Volts" and "On Access" are not polarized; they are just contacts that open or close, so XCab's wiring should still work.
However, OP should verify from instructions that came with LED which lead is + and which one is -.
Then to be clear, wire it this way:
Last edited by RAD4Runner; May 25, 2013 at 12:45 AM. Reason: Added fuse and voltage test points
Old May 24, 2013 | 11:56 PM
wyoming9's Avatar
Red face
First thing to do is check that the switch works. This seems to be more of a problem all the time.
make sure the fuse holder holds the fuse tight.
check all the connections.
Break out the Multimeter check for voltage.at the different connections
Old May 28, 2013 | 11:11 AM
93Xtra-Cab's Avatar
Just following up, did you ever get this to work right?
Old May 28, 2013 | 02:39 PM
Thanks for checking, XCab. Actually I was just working on it last night after work, and no, the only thing I got out of it was another headache.
So I wired it up just like in RAD4Runner's diagram. I made sure the switch was working because I used the same one I have my inverter wired to, I just unplugged the inverter for the time being.
So with all the wiring set up exactly like in RAD4s diagram, the tiny light in the illuminated properly when flipped into the on position, but the LED did not.
Still very confused.
Old May 28, 2013 | 03:07 PM
slo6i's Avatar
This is the point where you would bust out the multimeter, or test light, and make sure you are getting voltage through the fuse, through the switch, to the + on the board, to the negative of the board and back to battery. You can also confirm that the switch does indeed work. (It worked yesterday is not a good way of diagnosing problems.)
The only thing that I can think of is that the switch is causing enough resistance to not fire the LED's, but that seems a little ridiculous. Next option is to wire in a relay that breaks the circuit to the led's directly, and use the switch to trigger the relay, rather than run the led power through the switch.
Old May 28, 2013 | 03:51 PM
RAD4Runner's Avatar
Yeah.
Cartercoulombe, when was the last time you tested the LED? Should work when connected directly to the battery. When it does mark the + and the - pins right away
Correct, and that means switch is bad. Throw it away.
Don't know, man. LED should not need all that. Something must be defective in the system.
Old May 28, 2013 | 04:05 PM
slo6i's Avatar
Thats what Im thinking too. But its just another option I suppose. Ive never had problems like this when dealing with LED's.
