Shackle lift pros and cons
Old 01-18-2010, 05:51 PM
wannagetrdone's Avatar
tell me your opinion of using lift shackles. known problems etc
Old 01-18-2010, 05:56 PM
Hayes's Avatar
I know that when used in the front it can cause pinion angle problems. That's why all the lift kit comes with the front spring hanger, to drop the front of the springs the same length that the shackles lift it in the rear. In the rear of the truck, I think it should be fine. I need to start looking at that myself.
Old 01-18-2010, 06:17 PM
4Crawler's Avatar
http://www.4crawler.com/4x4/ForSale/...es.shtml#FAQ12
Old 01-18-2010, 06:24 PM
Hayes's Avatar
4Crawler - Does a shackle "lift" move the axle forward or backwards at all?
Old 01-18-2010, 06:28 PM
4Crawler's Avatar
Generally not, since the front end of the spring is attached to the frame and the axle is attached to the center of the spring, that length is not going to change. What might change a bit is if you say had a shorter shackle that was angled backwards to a great angle and a longer shackle was installed, the shackle angle would be a lot less so you'll have less rear-ward movement of the axle under compression.
Old 01-19-2010, 12:59 PM
20twinz's Avatar
You can do longer shackles and just buy the pinion angle shims to correct it as well.....
justdifferentials
Just Differentials
09-08-2015 03:15 PM
justdifferentials
09-08-2015 03:13 PM
Shagool22
08-14-2015 12:24 AM
msane99
07-27-2015 06:14 PM
tpd143
07-07-2015 09:06 AM
Quick Reply: Shackle lift pros and cons
