sealing/waterproof starter
I went Mudding about two weeks ago for the first time with this truck and hit a deep water hole. Had water over the passenger side off the seat. Not good. Since then my starter doesn't want to engage without some help. It's only a mud truck. I never sees the road. So I was wondering if there is anything I can do to save the starter from doing this next time besides staying out the water?
I am unaware of any waterpoof starter.
Water itself shouldn't cause a problem. I would be more inclined to believe that the water was causing a short somewhere near the starter, or that the starter is coincidentally due for new brushes anyway.
If you're sure. Take it apart and look at it. Find out why it's not working.
Test it directly against a battery and listen to it, then open it up and see what you can see.
A lot of people bury their trucks in mud and water and they don't have problems with it.
You might be special, but find out why.
I am thinking you got enough dried mud that your solenoid contacts are not making contact. Could be mud keeping the brushes from contacting the armature
could also be they were pitted all ready and it was time for a change . In the case of brushes they were about shot
If you have a poor ground the added mud might be enough to not make it work if your starter was on the way out already
I know this is an old post.. wondering if anybody has figured out this problem... I just get the rebuilt ones from o'reilly's half the time mine still have the warranty
But during mudding season I go through them like crazy...
Went in a water hole last week.. I've been beating on my starter all week...
You could perhaps try and coat the solenoid in that brush on electrical tape.
Perhaps Silicone caulk might work as well.
I think the major problem is getting mud on the contacts or enough grit that the plunger does not move like it should.
Would it be better to keep it douced in wd-40
or think that might short it out?
see if this helps: http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
zombie_barbarossa
Oct 2, 2015 10:54 PM
