Sponsored by: CARiD
Rough idle
Old Jun 30, 2018 | 09:13 PM
Schwifty's Avatar
Rough idle
so I blew up my engine beyond repair so I bought a new one and rebuilt it. My truck is a 1995 3vze V6 4runner. The engine I got is a pre 91 3vze block. I got the new engine In and hooked everything up and set the ignition timing. It’s runbing really tough tho. On a cold start it runs and sounds fine, but as soon as it idles normally it runs really rough. I think it’s running rich because I can smell gas coming out the exhaust. It’s not a spark plug related anything because it’s all Been replaced(plugs, wires, cap, rotor). Any ideas? This engine got new injectors new and a new fuel pump. I also know the cams are in time and it’s not an issue like that.
Old Jul 9, 2018 | 08:02 AM
thefishguy77's Avatar
Have you put a timing light on it? Verified that all wires are in the correct firing sequence? Checked for vacuum leaks with a can of carb cleaner or starting fluid? What codes is it throwing? If its running that bad it will probably trip a code if left to run long enough. 3.0 are not my wheelhouse by any means. Just some basic trouble shooting for the symptoms you described.
Old Jul 22, 2018 | 07:35 AM
Schwifty's Avatar
Got it fixed. It ended up being the EGR vacuum line got switched so it was stuck open.
andrewmacc
Apr 17, 2018 10:11 PM
JP Purdom
Dec 19, 2015 03:56 PM
Phessor
Apr 19, 2011 01:12 PM
b18vteceg
Dec 28, 2008 07:51 AM
Chuki
Nov 4, 2006 02:57 PM
